Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
otto
Hello all,
@Grumpy
thanks.
@th3jester
SMs TPU wont work??? HA;ha. Youre welcome in my home. I can show you something. Did I say a TPU? NO! Just "something".
@wattsup
forget the ECD. Almost all my drawings are in this forum so you can use them. Of course I dont mind.
Im using only my MOSFETs and never used the IRF 7307. This used Roberto.
You should use the schematic I posted. This schematic is for a TPU with iron powder cores. Not for the ECD. I see youre using cores from yokes. As said, my last schematic. It works only with frequencies at a high level, not low frequencies! 24V from the power supply, without caps, diodes, resistors....but WITH an output transformer - got this, as mentioned a few times - from a nice man here.
@All,
Im now using a Metglas magnetic alloy 2714A as a core. Google this. Maybe you get ideas.
Results: great.
Im using this alloy because the 4" TPU had not much room for the collector, the controls....
Now I have a 6" TPU - 1 ring only - with this alloy.
I hopw I can this week build another ring so my TPU will have 2 rings connected together and I hope ....who knows??
Otto
th3jester
@otto
I'll be there at 12:00pm on Saturday July 5th.
Honestly I am skeptic to everything on this forum. And your post saying "something" proves my skepticism. Again, if this is a forum to work on developing "free energy" why not tell everyone what that "something" is and give very detailed plans on making it without leaving ANYTHING OUT!!!
If you've already done so with this "something" then show me where the link and info is at.
wattsup
@otto
I think I will wait until you return from your vacations and simply put this project aside. I made the connections as per the dual  diagram but am still confused about the mosfet and how to connect it, and how to run it. My power supply can go up to 32vdc but even at maximum voltage, it can only supply 5-6 vdc at about 5 amps, so something is wrong and I will not surely spend hours searching through the threads for more specifics. I think what is required is a more formal explanation on the set-up and exactly how to connect the mosfet (pin by pin) and how to run it, otherwise I am simply wasting precious time that I can put elsewhere. So I will wait until you return form vacation and take this up then.
otto
Hello all,
@th3jester
This something is my newest TPU made with Metglas magnetic alloy. Its still in the construction. As I already saw with 1 collector and 4 controls it looks good but I have to build another collector with 4 controls so I can get more power and have more possibilities for various connections.
I will post the plans, thats for sure but as said, its not ready. Heeeeey, Im not hiding!!!
@wattsup
Im not anymore on vacation. This is the bad news. The good news here:
Connect the gate directly to the output of your oscillator.
Connect the source directly to the minus from your power supply.
Connect the drain directly to your coil or coils.
Thats it!!
If you have a car battery then use it. If you have a power supply then its OK but is your power supply with a current limiter? If so then it cant work because when we have a saturated core the current will rise to a lot of amperes. Maybe 5 - 10A and then you have to detune the frequency mix a little bit.
I hope this helped a little.
Otto
