Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Neolystic
@Bolt
I agree that it's likely about scalar induction.  The test is intended to go back to SM's 'very first thing I told you about', and assumes that there is a correlation between total power contained in a wave or pulse and the scalar force projecting at 90 degrees from the wire.  This, as everything else, is only an assumption, one which may or may not be valid once tested.
Also, I found no reference to 'Bordland Labs Scalar Energy Transfer'.  Do you have a link?
Thanks,
Neo
Spider
http://video.google.nl/videoplay?docid=-6461713170757457294&ei=LFsPSffrK5Kw2QLFrNCmCg&q=borderland+dollard
I think this is what he means.
Neo,
your investigation sounds really interresting, maybe you should devote a topic to your results
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
Grumpy
Quote from: Neolystic on November 03, 2008, 03:07:27 PM
This may be a reference to the experiments and video with Eric Dollard transmitting across the San Francisco Bay with a Tesla Coil.
You can Google: eric dollard tesla video
        -Frank Edwards
giantkiller
Get rid of all the moving metal and sequence controls.
That alleviates the mechanic resistance. The power comes from the resistance of the magnetic action against the aether.
Lets talk 3 phase or 3 freqs. When you heterodyne you are inputing nothing that moves. But there is a force that moves. What is it? Harmonics with the environment. How come nobody metions aether? Tesla does! Not standard academia. It is not the discharge but the charge. We don't conduct it we collect its flow. In the SM17 demo it lights light bulbs(inductors), it powers ac equipment(with an inverter), SM holds up 2 cables and shazam! Sparks. Big mofo sparks. That is the energy circulating in the coil. He makes a special connection to conduct the energy in another way.
Air coil, high Q and you can crack the universe. Harmonic of the circumference.
TPUs circulate. The GK4 jack hammers. See the difference? Around the coil and up and down. Beautiful.
TPUs produce power out. GK4 ejects power at the electrostatic level. Ooooh.
So this means we can drive any circular multi layer coil with 1 freq at high Q, harmonic from 3 angles of 120 degrees and the heterodyned sum should ring pretty loud while spinning is brushing the collector. Sounds like Hubbard. There is something out there. Is science fun?
--giantkiller. Aether... It's not just for dweebs anymore.
wings
Quote from: Spider on November 03, 2008, 03:15:05 PM
Neo,
Spider
my be this document can help:
para 3 Advanced electric concepts
para 3.4.3.4. Dr Meyl's Personal Tesla Coil Experiments
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20050170447_2005172301.pdf
