Thanks to ALL for your help!!
Johann Bessler information
Started by John Collins, May 23, 2008, 02:43:26 AM
Alexioco
ah yeah, so once pushed gravity will help take it out of equilibrium, how does the yellow ball balance at the top? This is getting rather interesting  :)
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
hansvonlieven
If it is perfectly perpendicular it will stay
Alexioco
WOW now that is called a WEAK balance, if that was the only balance a wheel had then it would perpetuate with ease... So about the spinning top, you say it might represent an inverted pendulum?
hansvonlieven
Yes, possibly with some mechanism inside that upsets it's balance in certain positions
Alexioco
Quote from: hansvonlieven on May 28, 2008, 07:32:55 PM
May I add?
If you get a long inverted pendulum {strong spring} with a 5 pound weight on the end, then under the pivot attach a short pendulum with a big weight that weighs JUST enough to keep the small weight up, then once a small force is applied to the top weight it will fall down then come up again...
It would have an upward force equal to its downward like Bessler said...
Also calculate the distance the large weight has to move to lift the small weight...
Could this be something?
