Fracturing Water Using High Frequency Electricity.
Started by gazzzwp, May 30, 2008, 02:09:08 PM
ggx9
I don't remember where I saw it, but a 250Volt DC pulse 1 microsecond long with a 7 millisecond delay between pulses will produce far more HHO than an equivalent amount of continous DC power. A fast rise time may or may not be important. I have not tried this.
For a precision signal source (I don't think it will give the above mentioned waveform) go to www.educate-yourself.org and look for the NC tone generator. 30 days free and no complicated programing.
Richard
TMGhost
Need some help....
Have i understand this right ? have read about it on wikipedia, but cant say I'm so much smarter  lol
A Transistor can be turn on or off, just to control the gate
A Thyristor, when you enable that, it cant be turn off before the volt that run through the Thyristor is Alamos zero, right ? so using that with DC is not possible ?
A Triac ? Same ?  or can this be turned off when i want ? or is it same as the Thyristor ?..
Regards Christer / Sweden
Jokker
Transistor is like a switch .. switch what is controlled from base or gate ( open & close)
But thyristor is not a switch or amplification element coz it will close when too much current passes ....
Buy the ticket !
Take the ride !
professor
Thought you need DC to do that?
Unless of course you use a Aluminium and one steel electrode and Baking soda or other catalysts  thus forming a Half way rectifier.
Quote from: Jokker on June 15, 2008, 02:56:55 PM
In my opinion there is no need to believe all what is told or written.
Also u can see amazing results by plugging your cell into wall. 110 v 60 hz will work like a charm.
I'm into this "overunity" thing. It is interesting and attractive.
On the other hand i want see a results (made by other ppl) to build it up. So far iv seen nothing so convincing!
Im quite good at electronics... so i can easily design circuit with needed output.
But i want to be sure that this thing will work. yea its tricky, coz there are no 100 % guaranty.
By the way it will be very easily to design very universal circuit by using driving and amplifying, by using amplifying there will be big losses... and so on and so on.
professor
I read somewhere and saw a Video on U-tube where someone claimed to produce hydrogen and oxygen seperation by simply submersing a strong magnet into a water- vinegar solution.
I tried that and left the neo. magnet in that solution for a day and nothing happened.
However I saw in a Video that the north pole will push the bubbles (don't know whether Hydrogen or Oxygen ) to the right and when you reversed the mag.Polarity the stream of bubbles where pushed to the left or vice versa.
It could also have been that the oxygen was pushed to the right by  the south pole and the Hydrogen pushed to the left by the North Pole or vice versa.
The answer needs to be found. I am only a electronic tech, this is above and beyond my knowledge.
Quote from: triffid on July 04, 2008, 05:21:17 PM
I found out a little more about that magnet trick.It seems that hydrogen is replled by a magnetic field but oxygen is attracted to a magnetic field.So the magnet wants to tear up the water molecule apart anyway (all by itself to a certain degree anyway).In my experiments I used an electric current assisted by magnets.When I used magnets by themselves I got no bubbles.This came from an article on chemistry that I found on the web.Triffid
