HHO as the only fuel (Brown's Gas) creates Vaccum
Started by zenarrow, June 18, 2008, 02:33:47 PM
Carbide_Tipped
The current pop-it valves will not work with vacuum. Did that already with a reground cam 4-stroke. Valves will always get pulled open. The force is applied to the springs when you want it at the piston. :)
Edward Kunkels pump that jeanna was talking about has me intrigued. I have done many cell ignition tests and concluded that a HHO water pump could work.
ltseung888
Can any one explain the mechanism of Browns Gas Implosion in greater detail?
I am particularly interested in the molecular structure of the atoms and molecules involved.
Imposion means external gases will rush in to fill the vacuum.  Work and energy will be supplied by the surrounding environment.  Apart from Browns Gas, are there any other known cases of implosion?
MarkE
Why do you find it remarkable that gas is less dense than liquid, or that a quantity of gas molecules at some temperature and confined to some volume exhibits pressure as described by the gas laws?
