I tried to rebiuld a Don Smith Device
Started by GM, September 25, 2005, 04:19:40 PM
Google
Has anyone ever tried the enclosed schematic or someone aware of real results from a similar schematic or maybe some YT video ?
Best,
forest
I think it would work if you work out it  ;)  This idea is correct but need modifications. See also Don Smith 2001 video about the same using metglas core
Jeg
I think that if you setup properly one secondary then it is easy to apply the same principals to more secondaries.
It is not an easy task though. The energy passage from primary to secondary needs to be flawless and that happens only if you match both sides in wavelength terms. i.e both of them have to have a 1/4, 1/2 or full wave relation.
Google
Please suggest the modifiactions. Thanks.
Best,
Google
Hi jeg and forest,
I will take .50 mm wire for primary 1 meter length and secondaries as 0.25 mm wire with 4 meter length.
Primary former will be 1.5 inch and secondary former will be 3.50 inch dia.
If in a room we have 1000 tuning forks of identical frequency and one of them is vibrated with some input energy, the rest 999 will also vibrate and produce more cumulative sound output compared to the one which we are vibrating.
Correct me if I am wrong.
Best,
