URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
xbox hacker
Groundloop
@xbox hacker,
Thanks. :-)  I will start soldering the boards next week.
I have started to convert my motor in the mean time.
The water pump is off now and next step is to add a generator.
Need to modify the motor front to keep the bearing in place.
I think some aluminum will do fine here. See attached image.
Groundloop.
Groundloop
@goldenequity,
I have made a cleaned up drawing of the circuit. I did not get the number of diodes used.
Also, in the car he used another string of diodes. Where to put them?
Can anybody that are better in understanding English than me take a look at the video and update
the drawing with the correct number of diodes and also where the second string
of diodes is attached?
Groundloop.
gotoluc
Quote from: goldenequity on September 13, 2008, 10:45:42 AM
A working plasma ignition setup in a Volkswagon van  :)  Using your low current circuit Luc!! Plasma generation, under compression, using 1/2 amp!!!! Nice.  ;D
circuit
http://skyhero.com/Cozzco%20Plasma%20Arc%20Circuit.pdf
video
NexusPlasma01.wmv
Hi goldenequity and everyone,
this is great news once again... this demonstrates the power of sharing ... the more we do the more we receive (growth).
I had a feeling we could piggy back on the existing spark switching system I guess that's why I was in no rush to by SCR's and was trying to even use my relay on the test engine. I was really hoping someone was going to solve it soon.
We are not out of the woods yet. We must work together to create a complete circuit which will include a pulsed coil instead of an inefficient inverter. This video is my attempt to show a more efficient circuit than using an inverter and if I can do it it aint that difficult. http://www.youtube.com/my_videos
I have had a vision for a while of a single box most anyone could installed in a vehicle to create the plasma spark. If the vehicle is a 6 cylinder the box would have 6 holes on its side fitted with male tip plug connector so you unplug your existing ignition cable from the spark plug and plug it in the box which would also have the same amount of wire lead coming out to connect back to the plug. This box would also have a circuitry that would give one the ability to retard the timing just by turning a pot to which could also be mounted inside the cars on the dash board.
I hope this is not too high of a goal to reach. Seeing all the talent that is coming together I am faithful we will achieve this. We can create a complete kits, circuit board, coil, components and all parts needed. That way anyone around the world could buy and build it or have someone build it for them and install. This would create work and income in every part of the World. This way everyone can make some income with it, since God knows there is allot of combustion engines out there.
Thank you all for your excellent research and development so far
Luc
gotoluc
Quote from: Groundloop on September 13, 2008, 04:08:55 PM
@goldenequity,
Groundloop.
Hi Groundloop,
thank you for this most excellent way to demonstrate a circuit wiring diagram. I like this style since so many will be able to understand it since many have good visual skills but no electronic skill. I know you are asking for help to complete the circuit. The help will come.
If it is at all possible from now on, can you please use this circuit illustration program to do all your circuits to help those with no electronic knowledge. It is important for the information to be easy to understand so many can share and replicate.
Thank you once again for your great service to the World.
BTW he said he used 30 diodes but also said it could be much less, also the other diode sets are used to prevent the other plugs to fire when the dedicated plug fires.
Luc
