URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
0 Members and 38 Guests are viewing this topic.
gotoluc
Quote from: whopper1967 on July 15, 2008, 05:09:28 AM
Well,I finally got my parts today,tried lucs circuit,and x box hackers.Obviously something went awry,in xboxs,I got no spark at all,in lucs my inverter would trip internally anytime it was hooked to the rectifier.The inverter itself works fine,I used it on several different things,it is a 400 watt 110 volt.The rectifier is a 50 amp 1000 volt rectifier.It seems as if I have a short circuit anytime rectifier is hooked up.Anyone have ideas?Thanks in advance,I am trying to learn this.....BTW,if anyone else is in the same boat as me in electronics,here is a great learning tool.....    http://www.allaboutcircuits.com      .For the red light I am getting..the manual says....THE RED LED INDICATOR WILL TURN ON, AND THE INVERTER WILL TURN ITSELF OFF AUTOMATICALLY IF:
1) THE CONTINUOUS DRAW OF THE EQUIPMENT BEING OPERATED SHOULD EVER EXCEED 400 WATTS.
2) THE SURGE DRAW FROM THE EQUIPMENT BEING OPERATED SHOULD EVER EXCEED 800 WATTS.
3) THE CIRCUIT TEMPERATURE SHOULD EVER EXCEED 165 DEG F.
Hi whopper1967, if you are using my most current Schematic you can just plug it in the wall or use a resistive load like Shanti mentioned to smooth out the surge on the inverter when the capacitor is charged.
Luc
Added: Thanks Shanti and everyone for helping out here.
whopper1967
qiman
I wrote this up yesterday as 1 of several parts to give a step by step walk through on what is happening. With the HV diode everything changes. Also, for fun on a non-related topic, check out my new youtube vid:
http://www.youtube.com/watch?v=HcZEDxoZpP8
This is possible by knowing what the potentials are doing in a circuit and how they interact with each other. That applies to this plug circuit in a subtle way.
plasmastudent77
Hi all,
As a newbie to all this, can someone please explain with Gotolouc's latest circuit diagram, the SPST swtitch/relay please?
(1) Is the switch replaced by high speed electronics/high speed relay if being used with an engine or is it just switched on and off just once to start the process?
(2) Is it synchronized with anything or any part of the motor revolution/ignition timing?
This may have been covered but if it was I wasnt able to find it, so apologies if that is the case, but once I understand a concept, I think I can add value to a discussion.
I'm just trying to understand. I have an engineering background of sorts, but always assume we never know everything and should be humble and open to learning.
Many thanks,
Steve
gotoluc
Quote from: plasmastudent77 on July 15, 2008, 08:45:13 PM
Hi all,
Many thanks,
Steve
Hi Steve, welcome to this topic. At this time none of us are operating a combustion engine with this circuit. What we are doing is replicating observing the effect sharing our findings and circuit improvement ideas. Some have been testing it on an engine but have not succeeded in making it work wet (that I know of). I think there maybe more for us to understand before we can get to that. Hi speed switching or timing synchronizing I don't think is an issue. We need to understand and find the way nature would use this so we can harness that power to work for us. We are not there wet as we have all been told how things work and it is very difficult to see it another way. I have hope that if we work and share together that the natural forces will conspire to assist us. Group participation and an open mind to learn is going to be the key here and I can see from what you write that you are there and here now.
Welcome aboard
Luc
