Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
innovation_station
the 8 cylender distrubitor cap is used for..... exactaly how it is named no?
it is your timeing or rotating spark gap or spatk gap
ist
Grumpy
Quote from: z.monkey on July 16, 2008, 11:53:36 AM
Howdy Y'all,
Here ya go!  The distributor is distributing the high voltage pulses to the coils on the device.  In this case he is artificially distributing the energy around the periphery of the coil.  This is the forced, not the natural, way to generate the spinning magnetic fields.  The natural way would to place all the coils in a series loop.  The series loop works out its own resonant frequency.  While the forced loop would have to be tuned by varying the speed of the motor driving the distributor.  It is clear to me now that the method used to achieve the resonance is less important than achieving resonance.  It can be done many ways.  The spinning resonance in the peripheral cores generates a vortex longitudally in the center core.  This is where the "Radiant" energy is collected and utilized.  The radiant energy is sucked into the coil from the surrounding environment where it breaks down into higher energy particles and is collected by the center core.  The term radiant energy refers to the energy available in the form of Soft Particles which have their origin in the energy that we receive from the Sun.
Blessed Be Brothers...
Alright.  Now we are engaging in productive discussion.
Distributing pulse yes, but forget the rotating "magnetic field" stuff.  That is an EM approach and won't git 'r dun.  HV is not a means to generate magnetic fields, but it is the means to manipulate "dielectric fields".  Whatever you are thinking, which is along the lines of EM - do the opposite for "dielectric flux".  If you've never heard of "dielectric flux" - look it up in a HV engineering book - it is quite interesting.  Take a whip antenna - EM is at the sides, the good stuff is at the end.
"Radiant energy" may refer to "soft particles", but "radiant electricty" has nothing to do with "soft particles" and everything to do with "dielectric flux".
        -Frank Edwards
giantkiller
The end of the atenna is the impact exciting zone within the metal and also the cross over point between the metal and space. This is where the higher energy exits. Em being the slower energy along the shaft. The exit point should produce a ball or longitutidinal ring? Or does it matter? Am I off base?
This equates to the end of the single wire transmission posts.
--giantkiller.
Grumpy
The end of the wire, especially with a small metal plate attached at each end, produces a longitudinal wave and can also receive one.
Design the system for piss-poor EM functinality and you get bitchin' longitudinal functionality.  Not mine - Patrick Flanagan's.
I was jsut pointing out that transverse and longitudinal waves are opposites.
        -Frank Edwards
Grumpy
PS Grumpy, sorry I called your version of the Hubbard Coil absurd.  Obviously it is a later design, and is far more powerful than the "normally aspirated" version I am building.  The one that is pulsed with the 11.5KV could potentially power and electrogravity spacecraft.  Is this what you have been working on?  Cool!
I appreciate this even if you are being sarcastic.  Emotions do not translate through words so it is hard to interpret true meanings of words.
See, I knew I never should have mentioned AG.  No one can resists it's sultry call.
Hubbard got several KW out of his devices - damn impressive.  I am not convinced that he looped it back, but if "out" is greater than "in" - who cares?  He said it would run forever once started with a pulse (like a TPU, which is believed to be looped back)
There is one other approach that looks very interesting:
You have to cause a change in the density of space (and also time) across a conductor to generate electricity.
Remember the tetrahedral TPU-ish thing that "Spherics" posted?  This is no different.
You creating a rotating field of pressure and it causes a flow of "energy" across the output coils (and the input coils in this case) and electricity is produced.  It takes almost no current and only HV.  All that is required is the right configuration and the right pulses.  To achieve this with this arrangement, you pulse the center coil each time an outer coil is pulsed - sound familiar?  This sets up the rotating pressure field (or field of different density) through the outer coils and around the center coil.  Pulse sequence is CCW in northern hemisphere, but shouldn't matter with enough bias from the cores to stomp the ambiant field, but may matter in reagard to the magnets, so would go with CCW and north poles up on the eight coils and down for the center.  See, per Wilbert Smith, you change an electric field in a magnetic field to cause force on tempic field - and this is what we are doing.
Would look like a toroidal magnetic cage - which is kinda cool.
Cores are "magnetized" - wound on insulating tube with magnet inside.
Adjust the pulse rate (motor speed - Hub used a variac) for best effect - not really a resonance.  Pulse rate is pretty low - hence the motor and distributor.  (he also had a gearbox but pulse rate is still low and reasonable)
This would be my plan of attack - straight out of the gate.  At the low pulse rate I doubt the magnets own freq would be found regardless of the magnets used, so they won't explode.  It's inherently safe, which is pretty damn cool.  Maybe there is some truth the story of "devine inspiration".
        -Frank Edwards
