Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
z.monkey
Howdy Y'all,
A centrifugal pump forms a vortex that you could use to push, or pull water through a hose.  I am using words and theories that you are not familiar with, ie Soft Particles.  Grumpy, you and I have the same exact thing in our minds, our brains are using different words to describe them.  I run into this all the time in international forums.  You and I are both right, we just explain the details with different words...
Blessed Be Brothers...
Goodwill to All, for All is One!
aleks
Quote from: Grumpy on July 16, 2008, 11:13:44 AM
You are on the correct path, Aleks!
Oh, yes, thanks. But it's what I'm persuading starting with my 'DC acoustic waves' hypothesis. The cool thing is that acoustics easily translates into aether plane (except wave polarization). Per hypothesis, acoustics directly can be used to create mass fields. Things are interrelated. Sonoluminescence shows that acoustics (inter-molecular/atomic kinetics) can be used to emit light.
giantkiller
Quote from: Grumpy on July 16, 2008, 03:04:48 PM
Everyone's confusion is confusing me.  At this point - keep it simple.  No resonance.  Don't focus on the magnetic fields - focus on the space around and between the coils.  No radioactive stuff.  Just some coils - like SM said.  Like squeezing water through a hose.  If  the following squeeze can pick up the previous squeeze, then we can gain a significant efficience by squeezing and then squeezing the same stuff again so it is more compressed.
So, before we get carried away and shell out good coin that could be spent on gasoline, let's take two coils, magnet in each, and attempt to see our "effect" in the secondary.  Smae wire for primaries, same length, center coil 2 times diameter of outer coil, secondary on outer coil.  Look for the goods on the outer coil leads.  See below:
I hear and obey the simplicity....
--P.
ramset
Grumpy made a great suggestion   a small cheap SAFE proof of concept    will there be any takers? Chet
Thanks Grandma
z.monkey
Howdy Y'all,
I already made the materials purchase.  So, I am going forward with my original plan.  This device should scale well...
