Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
giantkiller
The magnetic cage is formed by the outside coil magnets with North facing up. The center coil magnet is South facing up. This smacks of Leedskalnin. There is a flux or magnetic field loop.
Since the outer coil is 1/2 the diam of the inner coil that gives us a ratio 2:1 turns on the outer primary and the inductor on the center coil.
Will wind 300 & 150 turns on cardboard tubes to control the diameter since the wire length is the same on both.
--giantkiller.
Grumpy
Quote from: z.monkey on July 16, 2008, 05:02:42 PM
Howdy Y'all,
A centrifugal pump forms a vortex that you could use to push, or pull water through a hose.  I am using words and theories that you are not familiar with, ie Soft Particles.  Grumpy, you and I have the same exact thing in our minds, our brains are using different words to describe them.  I run into this all the time in international forums.  You and I are both right, we just explain the details with different words...
Blessed Be Brothers...
I agree and encounter this too.  Alek's explanations sounded "odd" until I cross-referenced the terms and then they made much more sense.  All three are different perspectives of the same sort of thing.
Now, this Hubbard thing is not so hard with our new perspective.  The only tricky part, as with anything that is built and not "engineered" is that it has to be "tuned" to find the optimum operating parameters - which is tedious.
The simple parts list is as follows:
8-pole rotary spark gap with speed control - rpm range of 1000 to 3000 (got to start somewhere)
8 outer coils with primary and secondary
1 center coil with primary
magnetized cores for all coils
hv power supply at 8kv to 12 kv DC  (even 2k will show something)
something to mount it all on
Latest diagram:
        -Frank Edwards
innovation_station
awsome bro awsome....
hey did you all see the self runing water wheel  ;D
verry simple... device only a few moveing parts lol
check it out here   http://www.overunity.com/index.php/topic,5176.0.html
now that is cool ...   just waite till he figures out the speed part of it  ;D ;D
ist
giantkiller
@Grumpy,
I am thinking 8 stun guns would be sufficient for a HV supply or a Blocking oscillator to 8 step ups fed by a mux? For a single channel to start with a 555 to a ignition coil or a flyback. I got all this.
I just had to go there.
--giantkiller.
Grumpy
I am miles from a bench and in envy.
Let's take two coils - set them up - hit them - and post pics of the effect for all to see (assuming we see anything), lest there be any "confusion", and then the scoffers, nay-sayers, and debunkers can pound sand.
Anyone see how close Dollard's / Naudin's TEM / LMD wave test is to this?  Hmm?  Sideways inductors?  Strange coincidence?  Magnetic field comes out the end, our field comes out the side.
http://jnaudin.free.fr/html/lmdtem.htm
        -Frank Edwards
