Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
z.monkey
Howdy Y'all,
Thanks for the Praise on the Soft Particle Reactor EMDevices.  I have a significant amount of time in that project.  It looks like I am fixing to build another coil also.
This is an excerpt from the book The Ultimate Reality by Joseph H. Cater.
"During the time of his demonstrations, Hubbard made a sketch of one of his smaller generators used for ordinary electrical appliances (see Fig. 28).  It was approximately 6 inches long and and 5 inches in diameter.  It consisted of eight coils in series, wound on iron cores which in turn surrounded a slightly larger central coil.  The central coil was wound on a hollow tube which contained many small rods.  They were, undoubtedly, comprised of soft iron.  Four terminals extended from the unit.  Two of them represented the outer coils which received the input current, the other two came from the central coil".
"It is highly significant that both wires used in the generator appeared to be of heavy gauge, like those used in telephone or power lines with the same kind of insulation.  Each core had only one layer of this wire.  This means that only a moderate number of turns were used in the entire generator."
There seems to be two different stories about the Hubbard Coil.  One is the pre-intervention version which is an electromagnetic device which is a self sustaining electric generator.  The other is post-intervention version where Hubbard claimed to have used radium to power the generator.  He did work for the Radium Chemical Company and obviously tried at one point to incorporate radium into the device.  The original reports of the boat on Portage Bay in 1919 have no mention of radium.  This leads me to believe that the original device was purely electromagnetic.  I read somewhere that Hubbard claimed to have had an Angelic vision which instructed him to build the device.  I believe that this divine inspiration of the "Self Sustaining Electric Generator" is what we are looking for.  After Hubbard had constructed the device and tried to either sell it or obtain funding for his research is when things went awry.  Whether it was the money, women, or partying Hubbard seemed to loose interest in his coil.  It could also have been pressure by some force that does not appear in the documentation, because this force "edited" the documents to protect the guilty.  Considering the nature of the documents (Seattle Post articles) this editing was done in real time, meaning this force was always close to Hubbard.  So what we need here and now, in order to replicate his work, is the original Angelic vision in order to clarify what Hubbard's Coil really is.
From Cater's book I understand that Hubbard did not use magnet wire.  The thin insulation on the magnet wire limits the flux that develops around the individual wires and causes the flux to rotate around the entire coil.  By using wire with a thicker insulation we get more flux around each individual wire.  This also allows more current to flow in the coil.  Traditional laws of inductance may not apply to the Hubbard Coil.  I think the type of wire, and the core construction are key to replicating this device.
Blessed Be Brothers...
Goodwill to All, for All is One!
aleks
Interesting parallels I've found between that WIPO patent (http://www.wipo.int/pctdb/en/wo.jsp?wo=2007103020&IA=WO2007103020&DISPLAY=DESC)
and PMH. PMH seemingly recreates a super-conduction state. This patent also talks about superconductors used as "magnifiers" of electric current.
Another "energy from vacuum" patent I've mentioned above ( http://www.freepatentsonline.com/7379286.html ) reminds me of the recent Arata cold fusion demonstration. They also have pressurized gas that is pressed into ZrO2?Pd powder substance. Powdered substances naturally have "Casimir cavities" in them.
EMdevices
I'm not sure what I was thinking, or what I read, but I re-read what I posted up top, and the main coil is not on the outside, but on the inside of the eight coils.  It's still the same phenomena at work though, and nothing much changes.   Another way to think about this device is something like a SEARL generator. The eight coils around the perimeter bounce the magnetic field between themselves at high speeds and due to winding directions, ratio of turns between primary and secondary, etc..,  there is a preferential direction of ROTATION.  This induces the pulsing DC in the center coil without significanly degrading the trapped magnetic field, much like the permanent magnetic holder (PMH).    At least that's my understanding at the moment, and I'm working on duplicating it.
EM
z.monkey
Howdy Y'all,
EMDevices, so you are saying that we should pulse the external coils sequentially causing a rotating magnetic field around the central coil.  The Ultimate Reality says that the external coils are wired in series.  Think about this, as you introduce a pulse to the external coils wired in series the voltage in each sequential coil is going to lag behind the one before it.  If we were sending AC through the coils the current would lead the voltage by 90 degrees.  This would cause the voltage in each coil to come up in a sequence around the device.  If it is 2 phase AC then this would happen from both ends.  Two coils on opposite side of the device would come up to full voltage, then the next two coils in sequence would come up to full voltage, then the next two and the the next two.  The AC would cause the magnetic field to rotate around the device.  I built an frequency generator which used a bridge power amplifier and it can drive 2 phase AC.  I'll attach the schematic.  Hubbard must have used some sort of tube oscillator to do this, seeing as how he didn't have semiconductors to do it.  My analog driver board has a sinewave generator that feeds the bridge amplifier.  You can vary the frequency of the sinewave by altering the values of C1, C2, R1, and R2.
I am really starting to groove with this now.
aleks
Quote from: z.monkey on July 07, 2008, 10:23:19 AMEMDevices, so you are saying that we should pulse the external coils sequentially causing a rotating magnetic field around the central coil.
I've got an impression you do not need ANY pulsing or active electronics at all here. Pulses are induced automatically, and they are probably high-freq pulses. So, all you need is "power conditoning" - AC/DC rectifier and voltage transformer. This is what Hubbard's generator had beside coil arrangement itself.
