Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
aleks
I do not know it this is relevant, but here is some WIPO patent that also refers to Hubbard coil:
http://www.wipo.int/pctdb/en/wo.jsp?wo=2007103020&IA=WO2007103020&DISPLAY=DESC
Hah, there's more:
http://www.freepatentsonline.com/7379286.html
an idea.. just to write it down:
Free energy (overunity) can be solely described and achieved by inducing space non-linearity - the same as created by gravity. Since gravity creates a field of length standard deviation, any energy that enters into this field undergoes "length standard shift" which shifts EM energy spectrum and also increases kinetic energy of a body. If gravity field can be created at will, without reaction from energies and bodies that are present in the gravity field, the said energies and bodies can be accelerated and decelerated at will. Thus, no quantum mechanics ZPE is required to define source of overunity.
Vortex1
Great find Aleks
The first patent should be downloaded with drawings, a must read for everyone and answers many questions about the possible operational theory of SM's units.. I was amazed to see Fig 3, page 4/12 resembling SM's and Fig 6 page7/12 resembling Hubbard. The inductive central coil in fig 3 would definitely run hot.
......V
giantkiller
Quote from: aleks on July 05, 2008, 08:53:27 AM
One more idea... Windings on all iron-magnet core pairs should be wound in equal direction (CW or CCW), from top to bottom (or bottom to top). This is to ensure "magnetic current" that is held in the device goes in the same direction in all cores/windings. This will probably create "struggle" I was mentioning (current in adjacent cores will be obviously going in opposite directions).
It is also possible to use all iron cores, but interconnect them with permanent magnet bridges, as shown.
Yes sir! Just slip 22awg rat shack coils over the the iron wire bundles and you got Ed.L. for starters. Sure beats winding, eh? Throw in a air gap or 2. Bettery yet make a iron wire ring with an air gap and magnet. Damn simple.
Very sound direction here. Can use flux flow or current flow.
--giantkiller.
gyulasun
Quote from: aleks on July 05, 2008, 08:59:30 AM
Hah, there's more:
Hi All,
I am surprised to read in the above first patent that Hubbard (and later Hendershot too) used radium to enhance current in the wires...  Well then does this mean we are chasing an impossible task, for without radium we will never have extra output from the Hubbard coil setup???
rgds,  Gyula
Vortex1
Hi Gyala
QuoteI am surprised to read in the above first patent that Hubbard (and later Hendershot too) used radium to enhance current in the wires...  Well then does this mean we are chasing an impossible task, for without radium we will never have extra output from the Hubbard coil setup???
The author seems to imply in the patent that a photoconductive layer of cupric oxide can act somewhat as a superconductor by allowing low mass electrons from photon bombardment to achieve higher than normal velocities in an oscillating circuit.  There is an energy gain since in standard transformer action normal mass electrons never seem to exceed velocities greater than the photons inducing energy. If their wire was from overhead utility electrical salvage it may have had a nice coating of cupric oxide. Maybe there is still hope.
from the patent:
QuoteThe output coil is situated to receive the magnified inductive-photon energy from the energy-magnifying coil. The inductive-photon energy received by the output coil, which is comprised of a metallic conductor, is converted into an oscillating electrical current of normal electrons. In order for the electrical output to exceed the electrical input, the output coil is situated in such a manner that it receives more of the magnified inductive-photon energy than that which is directed back against the sending coil to act as a back-force. This "energy leverage" causes the electrical energy output to exceed the input.
This recent patent is a wild ride, replete with references and quite a good read, all 91 pages. If most everything the author says is factual, a lot of missing links are found. Should be easy to replicate without radioactive materials, that was just one other way to do it.
......V
