Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
giantkiller
I never fell for the radiation either. That was a ruse by the Radiation corporation to hold the simplicity under wraps.
You could start the coil with a stun gun. Not only the energy cycle but the potential expressed in the copper run will be charged by the gaping of the spark. In one pull of the trigger you get many pulses of varying frequencies. And the coil will express that potential along its length shooting out perpendicular.
I am tired of testing with the stun gun. It wreaks havoc on my pcs, router, equipment and dogs.
--giantkiller.
z.monkey
Howdy Y'all,
OK, GiantKiller, EMDevices, I have core materials to build 2 cores already in my possession.  How should I wind them?  I assume one with the Cook coils and a central single winding.  The other?  I have one set of cores that already has a single layer of #26 magnet wire.  With the fresh materials I was going to build the ring oscillator.  I can experiment with that concept with the one with Cook coils.  So I can wind the other one another way.  Also I have the ability to make the winding connections "programmable" with a set of jumpers or terminal blocks so they can be rewired quickly to test another hypothesis.
EMD Core.
I can do the Cook Coil Model with # 26 magnet wire for the secondary winding on the primary core, and #22 stranded wire with thick insulation for the primary winding on the primary core.  The center coil I don't know about.  One set of windings or two?  #26 mag wire or #22 hookup wire?  What about starting it?  Temporarily connect it to a battery?  Cap Discharge?  HV Pulse?  Stungun?  Off switch for the cook coil?  Disconnect a circuit?  All circuits?
Other Core?  Ring oscillator (I know that one) ?  Whadaya wanna do?
My cores are 1/2 inch inside diameter iron plumbing pipe with and 1/2 inch carbon steel machine screw filling the inside for the primaries.  The center core is a 1 inch inside diameter iron plumbing pipe filled with 1/8 inch round carbon steel rods.  All the metal is 8 3/16 inches long to fit the bolts.  External diameters for the cores are 0.850 inches for the 1/2 inch ID iron tubes, and 1.325 inches for the 1 inch iron tubes.
EMDevices, that article reinforces the idea of the cook coils, having two windings on the primary cores...
Blessed Be Brothers...
Goodwill to All, for All is One!
ramset
Gentlemen no suggestions for Z on this ?  any ideas ?  A fellow traveler willing to build and test and report? Chet
Thanks Grandma
EMdevices
@z.monkey, great that you want to experiment.   I've been busy and I can't at the moment.   Anyhow,  build the 8 cook coils, each with primary and secondary,  (secondary with thicker wire and fewer turns).  Make sure you follow the right connection scheme for a particular test.    The center coil is just a simple coil wound around the central steel bundle, use lots of turns (I would use the thicker wire size for this perhaps)
Now,  hook up the 8 coils in a chain making sure the poles all point in the same direction.   Hook primaries to secondaries, and so on.   This will determine the direction the pulse will travel. I would just pulse the center coil or one of the 8 outer coils, with a quick connect to a battery.   Monitor the voltage on the center coil and see if you observe any fluctuations.  If you do,  and I expect them if wired properly,  then the next step is to perhaps go for a closed loop and connect the output to the input (the 8 coils).   Anyway, that's one test I would do.
pauldude000
@grumpster
I gave you the fair shake of the stick, and read the "quoted" work, though I found it is information not new to me.
However, he was talking about two separate types of waves in the part you were referencing. Damped and undamped waves.
The damped wave is a decaying oscillatory type of wave.
Example: http://www.graphpad.com/help/Prism5/prism5help.html?reg_damped_sine_wave.htm
The undamped wave is one in which the oscillations are constant.
I am talking about neither, and Giantkillers scope shot does not show either damped or undamped. What you see is an additive or RAMPED (my term) wave, though the scope shot also demonstrates that it is not fully summing, which may well be a good thing.
It does not degrade (damped) or remain constant (undamped), but increases (ramps) in voltage over time.
Worse, you said that Tesla stated that it is unsuited for our purpose..... Interesting. He did say that it was unsuitable for his magnifying transmitter, quite specifically. Hmmmmmm.......
The magnifying transmitter sets up a resonance within the earth itself, then dumps current into this resonance to use the entire earth as a huge capacitive storage container. Point is, it uses the earth itself to store and transmit the energy. (Simply by tapping in anywhere on the surface of the globe.)
The point for this explanation is simple. I have seen NOT ONE TPU in ANY video, nor have I heard of any discussion whatsoever indicating the need for a direct earth connection of any kind...........
Therefore, what did his statement about undamped waves being the wave of choice for his magnifying transmitter, and undamped waves being unsuitable, have ANYTHING to do with applying to either TPU technology, or my statements?
Or are you just going to tell me to "take another blue pill" again...........
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
