Thanks to ALL for your help!!
S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
xbox hacker
Their has been some chatter at waterfuel1978 yahoo group about the ignition point as to the missing link to make the coil work ???
Here is a image to look at...
forest
Quote from: capacitor70 on August 12, 2008, 12:02:42 PM
Today I build DC to DC converter Its output voltage can be controlled from 100V to 600V, using TL494 and emergency lamp transformer, I am having problem to
run using 330uF 400V capacitor when I connect this it starts heating transformer and MOSFET (due to low rating of Xmer), it gives good plasma blast with 330uF at first time but after some time it burned transformer primary and TL494, Again I assembled all to see whats the problem keeping bulb in series with circuit to monitor current, and found that after first blast TL494 makes duty cycle to 90% because of this it dosen't work after first blast, But circuit is good for low value capacitor 10uF 400V.
Below circuit is nice just adjust capacitor and resistor to high frequency and make ferrite core transformer, only problem of this circuit is it is unregulated output voltage. No heating of mosfet and xmer. go with this circuit. for real application, I used this circuit on my bike for one day no problem at all. with plasma spark power boost is observed...
Capacitor70,
All is clear in this circuit except MOV RDN240/20. What's that ? I cannot find it. Are you using  replacement for this ?
forest
From the schematic I guess this RDN240 may be a bidirectional transient diode. Capacitor70, how is that diode rated ?
bxngoc
MOV is metal oxide varistor (http://en.wikipedia.org/wiki/Varistor). You can find it in a computer PSU. If you don't have one just leave it out.
bxngoc
