new 50 plate emd graphite cell very expensive!
Started by clarence1984, July 09, 2008, 03:20:03 PM
Justalabrat
Quote from: clarence1984 on July 10, 2008, 07:48:19 PM
Flow can't ever go the opposite direction or like propane BOOM! So just use propane setups and you guys will be fine.  Keep the pressure in and around 100 psi for safe usage.  Even if the tank sprung a leak it could never blow up unless the flow when into the tank instead of out from the tank.
??? :o :o
WHAT?? ARE YOU CRAZY? Just the heat from compression could ignite the gas!! You will have made a very large, very unstable, on a hair trigger BOMB!
passion1
Quote from: clarence1984 on July 10, 2008, 02:35:24 PM
.  With a graphite EDM rod inside 9021 aluminum which is the kind they build ocean boats out of.  I was able to get about 3months of solid run time before the aluminum was no longer working to at least 50 percent capability with stainless 316l I was able to get about 6 months before it was totally dissolved and working at less than 50 percent capability.  I have done the homework.  I have been doing this for a few years now.   Graphite is the only way.  I hooked up my first two 4x4" graphite plates and put them on my 12 volt power supply about 11 months ago and it's still going they look just as good as the day I put them in there.  This is all with a 3.75l (one gallon) container fixed current and voltage 12vdc 2amp with 10 grams of salt
Clarence
I am afraid you have not done your homework properly.
Your problem is you are using the wrong electrolyte!
If you use NaOH (Lye), or KOH as electrolyte instead of salt, 316L stainless steel electrodes will last for years!!
Passion
bxngoc
I see. Over twenty years ago when I was child one day I decided to make electrolysis experiment. I took two rod of carbon from AA battery for electrodes, made salt water as electrolyte. When I connect a AA to electrodes I got a mixed of hydroxy and chlorine gas.
clarence1984
that's cool if you want the real math and solutions to the problem of how to incoporate this science into your everyday life come over to my forum at www.beawindhog.com
Yucca
Quote from: Justalabrat on August 19, 2008, 04:28:07 AM
??? :o :o
Justalabrat is correct, it is hair trigger, perfect explosive ratio, be VERY CAREFUL!
Also beware that the smallest of static discharges in pipes/couplings will ignite HHO, but not LPG.
P.S.
I visited www.beawindhog.com and I love your wind generators! Very cool!  :)
