Infinity Coil
Started by z.monkey, July 11, 2008, 08:12:41 PM
TheOne
Looks interesting invention, I found a new patent (2006) that looks quite similar to that they even talk about hubbard in it
http://www.google.ca/patents?id=vI2XAAAAEBAJ&printsec=abstract&zoom=48
pese
Quote from: TheOne on July 12, 2008, 09:24:37 AM
Jes this is similar , BUT this was done and working  by HUBBARD
you ca fine some informations here: www.nuenergy.org/pdf/hubbard.pdf
O have lot of pictures an shematas also. If interested i send them.
I is (nearly)the same tat is described in Patents
Gustav Pese
TheOne
I read that on some site its quite interesting, Do you believe he really used radioactive material? More I think about it more I think he probably used some kind of crystal like in the Testatika machines, something that he found himself outside before experimenting with radium with the company that buy his invention.
pese
Quote from: TheOne on July 12, 2008, 10:14:39 AM
I have found my sources now:
> ------------------------------- hubbard
> http://www.amasci.com/freenrg/hubbard1.txt
http://www.rexresearch.com/hubbard/hubbard.htm
http://pese.150m.com/fe/FE-hubb.html
http://pese.150m.com/hubb/  here you find ALL
http://pese.150m.com/hubb/sparkplug.html
http://atl2.netfirms.com/engy/mutch/matrixlaw/hubbard.htm
http://rexresearch.com/hubbard/hubbard.htm
http://amasci.com/freenrg/hubbard1.txt
http://www.linux-host.org/energy/shubbard.html
http://www.overunity.com/index.php/topic,1761.1450.html
http://www.zpenergy.com/modules.php?name=News&file=article&sid=2206
hubbard KNOW the radiating metals (as moray.
perhaps only not dangerously ?ow powering sources have done an function as an catalyt (to bring the device in oszillation.
I belive aswell that TESLA CAR  have workes with his tubes 70L7 also that way,
that the "active" wmission from the tube "cathodes" have pushed the device.
Remeber that he used an tube that need 70volts heating voltage )instead
12 volt tubes.  In that car was installed only one 12 volt accu. So Tesla have "underheated the tube.
The tube have not amplifier or rectified as an "normal working" tube !
So he have used aotherway (and source in that tube.
Even it is know that other inventors have used "little ?harles probes" of radiant sources
to reveive powerfull electrical oscillations.
This devices must not be "suspect" BUT UNEANTED for the energa suppliers...
Not all that "radiate" must be "radio-active rasiating . But anyway , some of this sources are
used from some (most or all) this "inventors"
I dont know the secrets,
http://beam.to/zpe
(if somone have an answer)
Gustav Pese
Possibly you find above  the bst collection over Hubbard .
If sombody have other "powerful" links over him.
Pls use (also anonymously possibel) Answerback here
http.//beam.to/zpe
ramset
Z whats your opinion on this? I know there are two trails of thought on Hubbard and radiation or not? Chet
Thanks Grandma
