Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
hartiberlin
HI ResinRat,
many thanks for the update.
Please keep us informed about your new progress also in the future.
Looking forward to see you running this device
on the fuelcell.
Many thanks.
Regards, Stefan.
ResinRat2
ResinRat2
Hi Everyone,
I've been doing a great deal of experimenting over the last two weeks and I believe I have worked out how the Hydrogen Reactor will be wired to the fuel cell. Dr. Griffin's electrolysis process is endothermic and spontaneous, thus the unit will begin producing hydrogen on its own without power input. So it will immediately begin producing electricity.
On the diagram you will see that each chamber will have at least two electrodes, the tungsten chamber will be loaded with as many electrodes as it can hold to boost hydrogen production to its maximum potential, these will be wired as T2. The T1 will be a single tungsten electrode to be used for the sole purpose of regenerating the zinc electrodes. In the other chamber there will be two zinc electrodes for the production of oxygen and zinc regeneration.
On the right side of the reactor there is a capacitor to help smooth the output of the Fuel Cell which will be constantly varying due to hydrogen production and temperature. There is also added a load, which will be where the overunity energy will be collected from. The size of these two (capacitor and load) will need to be determined experimentally. The goal is to have the load extract all the energy from the Fuel Cell output except the amount needed to regenerate the zinc electrode Z1 at the same rate zinc is consumed from the T2 and Z2 connection.
Ultimately this unit should be developed to be completely sealed from the environment, with only two wires extending outside the unit. This is where the overunity energy will be tapped. The connection between the zinc electrodes would need to be switched periodically. Maybe once a day, in order to allow even regeneration of the zinc on each electrode, and also so no zinc electrode becomes depleted. Thus would be developed a machine that produces a continuous output of electricity, drawn from ambient air temperature; using NO BATTERY!
This would be the total realization of Dingus Mungus's idea of a completely sealed unit. All components regenerated; including the heat produced by the fuel cell and the water returned into the reactor chamber. Described in Stefan's own words,"This is a perfect 'green' energy cycle."
This is where my experimenting will begin once the PVC reactor is assembled and ready to use.
Thank you for your interest.
ResinRat2
I was looking over this idea and I thought it was interesting to notice that it encompasses three types of energy.
1)There is the chemical reaction that produces hydrogen. This reaction is endothermic, therefore it absorbs heat from the environment. I noticed that if the reaction is accelerated with a battery that it actually cools the liquid in the chamber at an accelerated rate.
2)The galvanic reaction produces hydrogen spontaneously. This reaction is catalyzed with colloidal Magnesium and Silver. The colloids are high surface area and allow the reaction to occur at a low activation energy (Low voltage) on the surfaces of the tungsten and zinc electrodes.
3)The hydrogen enters the Fuel Cell and converts the gas directly into electrical and thermal energy at a theoretically high efficiency.
So in this unit there is catalyzed chemical, electrical, and thermal energies that shuttle between each other and the environment. A very unique and complex mix.
Just thought you would find it interesting to notice.
Thanks for your interest.
ResinRat2
 Ok, my son's video is back up. Just a little fun to see, hear good music, and see the credits.
enjoy:
http://www.youtube.com/watch?v=SuUdcocg-BI
