Thanks to ALL for your help!!
Firestorm replications
Started by maybeHHO, July 31, 2008, 02:36:12 PM
maybeHHO
Just came accross this on Youtube...
Looks like the ozzies are making replications... can't someone in the US?
http://www.youtube.com/watch?v=hl9zXE7ntRQ
acid1789
Why would it matter where this was done?
The real question should be, what can we learn from this and how can we use it to move forward.
This is energy for the world, not for the US.
maybeHHO
Just thought it was important to share. I don't really care where it was done. I just have never seen anyone do it at all. The spark under pressure is amazing. It is also done with a regular ignition system. I would like to see what it would do with one of the high voltage circuits that are being discussed in other threads.
Anyone with more information on firestorm replicating please post.
Bruce_TPU
You will not be able to replicate the firestorm plug.  A good friend of mine and a member of this forum has the blueprints in CAD.  He did the plans for the original creators.
They used very expensive metals and there were a lot of problems with the plug.  This is why it was not reproduced and sold.  It has become another urban legend.  The MIB did not get them, and they were not poisoned.  The made a business decision not to continue, because of many of the issues that arose.
That is all I know from my friend.  Your time would be better spent designing your own ideas.  IMHO
Cheers,
Bruce
maybeHHO
Thats odd because I just heard a blog talk radio interview with the creator, Rober Krupa. At the time of the interview, he is saying that he still plans on making them. In fact he was on his way to Brazil because their government has shown interest in them.
Listen for yourself http://www.blogtalkradio.com/kywaterfuelmuseum/2008/06/02/robert-krupa
and maybe your "friend" needs to give you better information. The plugs were designed in a basement using old plugs, not some space age metals. The video Posted clearly shows a replication and it working. I didn't say anything about MIB.
why is everyone so hostile about the firestorm plug? bitches
