how to construct the easiest possible pyramid!
Started by nitinnun, July 31, 2008, 03:25:53 PM
nitinnun
CCW, is attracted to water molecules in sky (attracted, to waters hydrogen atoms).
pyramid allows CCW, to climb high into sky.
pyramid, is like up-side-down pot-hole.
CCW, is water filling up pothole.
CW, is attracted to sand in ground (attracted, to sands oxygen atoms).
CW is stored in sand/gypsum/granite, that pyramid is made of.
CW slowly fills up sand/gypsum/granite in pyramid, starting from peak, moving down to base.
pyramid, is like baseball-glove.
CW, is like baseball being held above ground, by baseball glove.
when CW touches ground, CW overflows into ground.
resistance in ground, slowly eats up CW.
until CW is used up.
nitinnun
i think this is how the pyramid was originally configured.
one metal attracted, what the other metal collected.
the peak attracted CW from above, and CCW from below.
Charlie_V
HAHAHA, you know.  The point of the pyramid is going to produce a field gradient in the earth's electric field.  If a floating conductive body is placed on the inside of the pyramid, it would charge up.  I'm not sure that the inductor itself is important because of how small it is in the drawings, but if the pyramid is charging at a particular rate, then this could make a resonant circuit and feed a load better.
Tigrotto
Hi Nittun,
Would you be so kind to disclose here with us your system to produce electric energy as to be replicated, please?
Regards,
tigrotto
P.S. Or better, let me know the thread where you just posted this info, please
