How a Testatika motor works?
Started by Magnethos, August 09, 2008, 05:45:22 AM
Magnethos
Can you explain me how the testatika motor works and post some interesting links?
Steven Dufresne
The inventors don't tell how it works so all we have are theories, ... many, many theories :-)
Other than the many demonstrations of the working machines, Paul Baumann, the main inventor, gave two demonstrations of basics that serve only as hints of how some of it might work, but even then, not with enough detail to replicate even those demonstrations. They are refered to as the Pinciple Experiment and the Linden Experiment:
http://rimstar.org/sdenergy/testa/principleexp.htm
http://rimstar.org/sdenergy/testa/lindenexp.htm
Methernitha's webpage (Methernitha is the name of the group that made the testatikas) also has some details of the workings a little further than half way down:
http://www.methernitha.com/Mether_2/Free_energie/free_energie.html
-Steve
http://rimstar.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
Magnethos
Thank you very much Steve, I'm going to read the links.
I can move a rotor with energy from the air, so my big doubt is how I can obtain energy like a testatika motor. Wind Generators needs to move at high rpm but Testatika can obtain 3-4 kW running at low rpm.
And I would like to know how testatika motor obtains that big amount of energy running at low rpm. I have read something about the linden experiment and the electron cascade or somethig similar. I'm reading some website but there isn't enought information.
Magnethos
Here you have some usefull schematics:
Steven Dufresne
Magnethos,
The above schematic by Paul Potter involves a lot of guesswork, but if theory is okay then here are a few more.
The disks could the source of the energy. George Woynar's group published a detailed theory about this back in 2005 involving plasma being formed between the disks and this pulling in electrons. See the following as I no doubt have gotten it wrong:
http://www.overunity.com/index.php/topic,70.0.html
The disks could also be producing energy using the same principle as the Hyde generator. See us patent 4,897,592:
http://www.google.com/patents?id=HX4BAAAAEBAJ&dq=4897592
Hmmm not much on the web about the Hyde generator. I'd better create a page so it doesn't get forgotten.
The magnets could be the source of energy. Paul Potter's electron cascade theory has the electron cascade happening in the area of the magnets. There have been similarities drawn with Leedskalnin's ideas and Roy Meyers' device:
http://rimstar.org/sdenergy/rmeyers/index.htm
I'm sure I'm missing a few more.
The two large pots (Paul Baumann's term for the large cans) could be the source of energy. I see the potential here for a non-mechanical Hyde generator, but there's also a strong correlation with Hans Coler's Stromzeuger (not his Magnetstromapparat):
http://rimstar.org/sdenergy/coler/misc/coler6.jpg
http://rimstar.org/sdenergy/coler/index.htm
Coler said that the energy was coming from between his plates and these plates correspond to the two large pots in the testatika.
Then there's the radioactive material theory. Paul Baumann said there was no radium in use but that doesn't eliminate other things. Stefan Hartmann was told during his visits to Methernitha that the secret was in the crystals and if you look closely at the smaller containers and the tall ones in back you can see some cylinders of crystal-looking material in them:
http://rimstar.org/sdenergy/testa/misc/test.jpg
Stefan doesn't mention radioactivity but my guess is that this material might be electrostatically stimulated to produce beta particles (high energy electrons.)
And I've no doubt missed a lot of other theories. There may also be more than one source of energy in use
I'm currently doing experiments with the pots, trying to create a lot of ionized air within them while having charge flow through meshes and perforated metal within them, while at the same time trying to keep my supporting circuit as much like the single disk small machine as possible.
-Steve
http://rimstar.org
