Thanks to ALL for your help!!
Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
singerxyz
This was so interesting, I thought it would be good to post- not exactly "Sun" energy, more like Central Sun Energy.
Tell me what you think...
http://www.nuenergy.org/pdf/electrinium.pdf
Drannom
 ;D very good and clever from you to suuggest a topic on the electrinium
in electrinium.pdf there is an easy way to produce free energy from the Central Sun
QuoteThe body of the Unit could be made from a number of materials such as steel. Silicon, Germanium, Carbon and others. Each of these materials would be suitable for an Electrinium Unit designed for a particular purpose. Units made with steel bodies would be of an extreme voltage, so high that they could not be cut and assembled into batteries, but they would be very easy to make.
it's all about catching Super light from black hole, from my point of view, we have talked about this a little bit in the Lee Tseug topic and in the Hutchison Crystal Battery topic
this is a very good explanation, the Central Sun give power to all blacks holes, blacks holes give power to all sun in the galaxy
there is a link on that
http://blog.hasslberger.com/2007/11/milewski_describes_magnetoelec.html
Quote......
SuperLight is described as the opposite and complementary phase to ordinary light. While electromagnetic radiation - visible light is part of its spectrum - has a strong electric and a weaker magnetic component, in magneto-electric radiation the magnetic component outweighs its electric counterpart.
Milewski proposes a model which sees magneto-electric radiation as the source of gravity, emitted by black holes and traveling at the square of the speed of light. SuperLight has a correspondingly shorter wavelength and higher energy content than ordinary light and is the source of the energy of life, which makes for its connection to the area of healing through increased coherence in organisms.
While physics has tended to exclude life and consciousness from its equations we now have - with Milewski's model - a very real possibility to reach unification with meta-physics, generally considered the purview of faith and religion.
Now, I believe a similar event occurs in the extremely dense and hot matter found in black holes. It is theorized that black holes contain magnetic monopoles and when these extremely dense, extremely small, extremely energetic magnetic monopoles release energy by lowering their orbit they radiate magneto?electric radiation, our SuperLight. So black holes really are not so black. They are radiant beings of SuperLight. Of course SuperLight escapes the strong gravitation forces of the black holes because its velocity is the square of the velocity of light and it therefore, can easily escape.
The current scientific thinking is that in the center of every galaxy in the universe is a black hole. There are billions and billions of galaxies all around us, and they all are producing SuperLight. We are literally bathed in a three-dimensional dynamic energy field, or an "Ether" of SuperLight ? a Dynamic Ether.
and much more at the link
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
devrimogun
Quote from: Drannom on September 02, 2008, 06:21:13 AM
Drannom,
I was very interested in this electrinium battery as I think it would definitely work.
Mr. Nelson of rexresearch wrote me that it came from aliens during meditation sessions of some
young people and they tried to replicate but failed.
The problem is they describe a way for fabrication from silicon which is not available to most
researchers. My chemistry contact thought that some important information was carefully hidden.
In your message I just saw the above quoted "could be from steel" and wonder if anybody can describe a
way to make this from steel or carbon or any other material but crystals. As crystals are hard to work with
and very brittle. One crack and your efforts are gone.
Drannom
Thank you devrimogun !
In electrinium there is a complex method to do it, there is also a simple method not described well (steel)
i suppose that steel can be overheat at red hot heat, an then cooling down slowly while putting a lot of volts in with a little ampere
each layer of iron-carbon will need a specific voltage to be compressed together, let's suppose there is 100,000 layers of cristallized steel in one milimeter, then the voltage needed will be very high, so it is preferable to crystallize a little piece of steel, let's say 1/10 milimeter for example, then you'll need many thousand volts for each 1/10 milimeter
In electrinium we have to understand the simple way by ourselves
the theory is simple, choose two molecule with different density, and cristallize them together with high voltage, then the two molecule will be nearer than in a natural way, this compressed compound will shine more super light and transform super light in electricity
many things is shinning more super light than chaostic things, every crystal shine more super light than chaostic things, most of them do not transform super light in electricity
secret military device include blue crystal producing a lot of energy (alien device give to military for underground basements, from projectcamelot)
the steel is the simple way to produce an electrinium from my point of view, so simple that we have only to try it
electrinium explan a new way to understand energy cicurlating in the universe, it sounds very accurate to me, the Central Sun theory with the Super Light let every inventor with a theory to fully understand every radiant device
radiant devices can catch Super Light or a consequence of the Super Light in the circulation of energy in the universe
my english is so bad that a can not explain it further
alll we have to do is understand the general principles, and then find out our own way to catch the Super Light
everythings must be simple, cause there is only a Central Sun giving power to all the eather, and alll the universe in only made of eather, then every atoms or molecules consume a lot of energy from the Central Sun, we have to break the equilibrium to catch Super Light
for example a large spark can catch some super light
i know, it is not a pleasure to read my english, sorry
z.monkey
Howdy Y'all,
I have just read the Electrinium.pdf document.  I am familiar with the theory of growing semiconductor silicon crystals having been in the semiconductor industry for several years.  Now I haven't grown the crystals myself, but I understand the theory well.  In the Electrinium.pdf document Mr. Summera describes the theoretical process of "growing" Electrinium very well.  It makes perfect sense to me.  Ultimately you are making molecules of silver and iron.  These molecules are arranged in the finished material so that they are all polarized in the same direction.  This gives the effect of stacking batteries, but at a molecular level.  This results in high voltages at tiny currents.  Then the small, high voltage crystals are paralleled to increase the net current.  So say you produce one that is the size of a AA battery.  Rather than having a single crystal which traverses the length of the cell you have a lot of tiny cells which are paralleled in a matrix inside the cell.  This way we can replicate the voltage and amperage of a 1.5 Volt AA battery cell, but it is composed of something very different inside.  Something which is a permanent battery.
I imagine that the composition of the structure would be similar to an electrolytic capacitor.  Where you have an anode plate with its conductor to the east.  Next you place a thin wafer of the Electrinium.  Then you have the cathode plate with its conductor to the west.  Then there is a dielectric plate to insulate this cathode plate from the next anode plate.  Then the process starts over to add the next cell.  First an anode plate, then the wafer of Electrinium, then the cathode plate, then the dielectric plate, et cetera.  This would require several processes to produce the finished Electrinium batteries.  You would have to fabricate the iron silver molecules in one process and the silicon borozon mixture in another process.  Mix the two solutions together and grow the Electrinium crystals.  Then slice the crystals into appropriate wafers and fabricate the batteries.  Then to activate the batteries you would have to reheat the entire battery to 1200 to 1400 degrees Fahrenheit and apply a direct current to align the silver iron crystals.  When the battery reaches the right temperature, and the crystals align it will start producing current on its own.  Then you can allow the batteries to cool down with a resistive circuit attached to allow the silver iron molecules to retain their alignment.  When the battery is cool, and the silver iron molecules are physically set the battery is permanent and will produce current perpetually.
This is so cool!
Blessed Be...
Goodwill to All, for All is One!
