Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
resonanceman
Quote from: sparks on October 19, 2008, 04:51:29 PM
  What is proven is that a crystal has the ability to demodulate visible light into it's constituent frequencies.   So it acts like a radio demodulator circuit for light,  sorting out the different frequencies.  If these sorted frequencies are caused to interfere with each other and produce a frequency or interference pattern at a frequency that is very low and is imposed on an antennae that resonates at this lower frequency, we get direct conversion of light to electricity without relying on hit or miss photon collisions with electron collisions as occurs in photovoltaic cells.
  I am sure that the same mechanism could be used to demodulate and reconstruct lower frequency wavelengths like infrared to microwave or even megahertz or lower frequencies where resonant circuits are employed to charge capacitors.  These crystals would work night and day on any scource of infrared radiant energy like warm sand or warm ocean water.  One guy wrote a book about the Bermuda Triangle and believes that crystallized methane gas converts warm ocean water to microwaves that screw around with compasses and forms a mini aurora borealis effect.  Another guy believes that the pyramids were used to change infrared into sonic oscillations to send the Pharohs to oblivion.
  I know this isn't electrinium but while you guys are trying to make crystalline structures it would be worth a thought.  Two different crystals.  One to demodulate and the other to hetrodyne the demodulated highfrequency emwave into a lower high intensity frequency that is focused on an input antennae to an electrical circuit caused to resonate at the hetrodyned frequency.
Sparks
Using  your  ideas   about  demodulating  energy
Isn't  a diode  often used to demodulate  a radio signal?
In  electrinium   couldn't  the  electrinium  compound  be  a demodulator  and  the  silicon/boron  the  hetrodyning section ?
It seems to me that you  are talking about  resonance  and  frequency  where the  electrinium PDF  talks  about harmony .
gary
nitinnun
i just realized something important!
i have 2 sticks of steel, sitting in water.
the resistance is a few k-ohm's.
when i charge the 2 sticks with a 9 volt battery, the resistance becomes so high, that it is unreadable!
when i remove the battery, the resistance becomes SEVERAL m-OHM'S!
and then SLOWLY drops back down to a few k-ohms!
polarized water has increased electrical resistance??????
this is very important too me.
because an electrically resistant substance, allows my ZPE molecule to work.
i think the middle-substance would retain its electrical resistance, if its molecules hardened while in the polarized configuration.
john hutchison's cells cooled off while they were polarized by electricity.
so HIS middle substance would harden into the polarized configuration too!
nitinnun
when i used graphite powder instead of glue, there was a much lower resistance between the 2 terminals.
because graphite powder is a conductor.
the voltage was lower.
but the amperage was higher.
the graphite powder was NOT packed tightly. so i was surprised that the amperage was that high.
if lower electrical resistance means more amperage,
than i could get more amperage out of a ZPE cell, by adding conductors to the middle substance?
to sacrifice voltage, for more amperage?
nievesoliveras
Hi!
@nitinnium
I dont know what is happening because:
I was experimenting with two galvanized screws to see if even being the same would be polarity among them. The thing is that if you use a battery charger and put the two screws inside a cup with a pinch of baking soda, one of the screws will keep the negative polarity always and the other the positive polarity always.
The question here is: Will it be posible to align the atoms on the electrinium battery with a battery charger instead of using high voltage to do it?
Jesus
nitinnun
Quote from: nievesoliveras on October 19, 2008, 08:59:49 PM
Hi!
@nitinnium
Jesus
i would think that even a little voltage, would polarize.
but the more voltage/amperage you have, the "higher the quality" of the "polarized configuration", of the atoms.
learning that polarized molecules have greater electrical resistance, has caused me to came up with an improved explanation, for the polarized-configuration that i want, in my ZPE cell.
i'm still deciding on the best way to express it, in a drawing.
this improved understanding has me very excited.
