Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
sparks
    Three coils wrapped around a common core.   You can use copper wire air whatever depends on the frequency.   Top coil input sine sawtooth whatever as long as it is impeded.
Two ouput coils out of wack as far as impedance matching.  Pull a load.
    Allow time to get some ambient magnetic field input to reset the core.
             KICKS FOR FREE
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wattsup
@sparks
You are getting better and better with those Egyptian Hieroglyphic designs. Just joking.
On your previous post, if standing waves can be used, please explain how in the FTPU this could be done with what is already there. My idea of the iron ring is because there is a ring and there is winding in the actual TPU. Explanations and ideas should be as close to the device depiction as possible. A coil, ok, which one, where is located, etc. If you guys can keep this to specific parts of the TPU, then maybe we will understand more.
@forest
Regarding your post one more rings for the larger TPU, I don't know. It seems there is still only 6 total loops when you look at the cutaway photos. The 6 looped ring is simply of greater diameter.
About frequencies, yes, guys have done this on the forum for years. Look up Otto's ECD. In some of my coils I have found that if you pulse one frequency to find the resonance, then apply the second frequency at the same frequency minus 1 hertz and shift it's phasing by at least 6.84 degrees, you get real havoc and more voltage production.
But frequencies will depend on the power type AC square/sine, straight dc or pulsed dc or reverse pulsing dc, all of these will produce different effects.
otto
Hello all,
@wattsup
sorry to jump in but in a TPU is a ring. But not an iron ring. Its a copper ring.
Maybe you can show me where  the cutaway photos are?
Otto
wattsup
@otto
Hope you are doing well.
First of all, don't ever be sorry for jumping in otto. We always like what you have to say and teach and reading between the lines. lol
Well,,,,, the FTPU ring could be either iron wire, copper wire or other wire, but to better understand this, unfortunately all types must be tested. The logic behind each wire type must be looked at until we can understand the best methods. Same for the LTPU.
Everything I have on all units, photos, diagrams etc., is now available to everyone on my ftp site which is located here http://www.purco.qc.ca/ftp/.
Just look in the Steven Mark sub directory to find the TPU type and go from there.
Any file with the word "cut" will be off the cutaway video. I kept one of my companies open just for OU stuff because I can then declare all my R&D expenses. Why not.
I wanted to make this ftp site so I could have an easy way of finding things when I am not at home and also to provide others with all the images, etc., in one convenient location and not have to search the Forum, which is getting to be more and more loaded with so many other things. You and Roberto are on there also. If there are things you would like me to remove, let me know. Or add, then send it to me at contactOU@purco.qc.ca. Remove the "OU" from the e-mail I just gave you.
So I am not saying it is iron wire, but "if" it is iron wire, what would be the dynamics.
One main or major thing about the TPUs is the builds are all made with coil winds that are not that precisely spaced. This indicates that they are all relying on a main principle of operation that has enough leeway to accommodate build variations as long as the main principle is adhered to, the device should work.
Another important note about the FTPU center toroid and the LTPU center toroids. They do not seem to have the same winds. On the FTPU the winds seem to be much more with a finer wire and many layers, so the toroid  in the FTPU could provide a point of high induction. In contrast to the LTPU toroids that have a set and clealy vissible limited number of winds that I have already drawn and identified.
Then the question is why would you have more winds in the FTPU and I think it is related to the fact that the FTPU outer winds could never provide the point of high induction because there is simply not enough wire there, whereas in the LTPU SM could be using the outer winds to also provide the high induction point while using the toroids as an output regulator since the LTPU toroids halves are in parallel and there are two of them to handle the higher voltages.
I could go on and on for pages.
Now regarding the FTPU I know now there is a small transistor that has three long thin legs and there are some capacitors (3) one beside the other, then there is the front EM capacitor and there is also another EM capacitor in the back. There is also a 1" long resistor or fuse resistor.
If anyone is good with circuits, I would need a table of components that someone would require if they wanted to make a transistor oscillate at 5khz, 10khz, 15khz, 20khz, 2mhz, 5mhz, 10mhz and 20mhz. Based on a driving voltage of 3vdc. If anyone can give me the capacitor values required then I could look them up, see how they look in reality and compare them to what is in the FTPU. So you see, I have been trying to keep a certain level of methodology but my EE to do such a table is not good enough.
I know alot more today on the FTPU wiring and will make a new wiring diagram when time permits. But for now it is really looking, making and testing many variations. What else is possible to do in such circumstances? Those who are on this know of the many variables.
I also sent an e-mail to Jack Durban asking if he found his BETA video but have not received an answer from him. Booo hooo. That would have been great to have a better video copy.
sparks
Thankyou Wattsup for your work and sharing!!   So if we take a hf signal and inductively feed it to two chokes with different impedance matching but one is altered by the saturation parameters compared to the iinductance of the copper could we get some voltage between the two chokes that is unexpected.  Both chokes are setup to choke the ac input but one takes a little longer than the other.
    Spherics mentioned SM discovered this effect working with timing elements for his audio timing elements.  This anamolous spike could be captured by a capacitor.  I'm going back to square one on this deal and see if I can get the anamolous spike on my oscope messing with two identical torroidal chokes and changing one so that the copper in one is altered along with the core but still designed to choke the same frequency.
Think Legacy
Spread the Love
