Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
magpie
Quote from: innovation_station on June 08, 2009, 04:03:49 PM
RODIN COIL
If anyone needs help with a Rodin Coil, let me know and I'll do my best to be of use.
I do intend to make some more videos of the effects I have noted about the Rodin Coil soon as it is unique.
NOTE: Don't expect to get results by just shorting DC through it and hoping. Also don't be deceived by a moving magnet placed in the centre of the coil when you run AC through it. When researching this coil you should be careful to check if what you are observing actually IS unique, or if the same thing can happen with a normal coil with the same amount of wire and windings.
On a recent oscilloscope test I discovered that the Rodin Coil is an excellent inductor, especially for a coreless inductor. If I put in the right frequency in one coil, I found that the voltage output of the second coil ould increase, even triple, if I tuned to the right frequency, however, I have not yet measured the current output so don't get too uppity. I should point out though that the "primary" and "secondary" coils have the same number of windings so the voltage step-up is intriguing, I will double check my amplifiers, their voltage output is supposed to be 12 volts but you never know with Chinese products ::)
I think that one of the reasons the Rodin Coil makes such a great inductor is because the 2 seperate coils actually intertwine at the centre of the coil in a way, each coil is surrounded on either side by the other because of the geometry of the windings, I suppose I should draw an illustration to demonstrate this.
The Rodin Coil concentrates so much wire at the centre that the amount of inductance happening farther out doesn't matter so much because of the efficieny at the centre.
Geometry is essential stuff...
magpie
magpie
Quote from: Chef on June 09, 2009, 12:57:55 AM
Wake up for what?
Where is your proof?
Why the discouragment?
Tito L. Oracion
Hi everyone
no core is very possible, conventional transformer has a core to amplify magnetic field, i think, using copper tube is more better so that mag-wire is easy to wind.
innovation_station
i think a feroite toroide core ..
ou can be acheived easly ..
with one without causeing massive disturbances to comm equ...
group the cascade colapesing magnetic feild ...  pay for the first coil .. collect inputted power and kick in second cap and dump to following coil ... etc.....  get through all 3  and dump to the load ... scoope a tiny bit of the final coil  to replenish source to continue the operation ...
ist!
ps i can assure you there many ways ....  ;)
@ otto
is this what you mean isolate from source .....  :D :D :D
http://www.youtube.com/watch?v=Jiodkjo9hpk  :)
