Thanks to ALL for your help!!
what electricity REALLY is.
Started by nitinnun, September 07, 2008, 07:20:34 PM
nitinnun
this is the heart of the reaction.
saltwater allows a spin,
to be stored in one metal,
yet still be "connected" to the other metal.
THE REST of the device, just collects/generates CW and CCW.
except maybe for the two coils. which might have a diode effect, like drannon said.
which would explain why the CCW coil had more turns, than the CW coil.
nitinnun
this is the heart of the concept.
the steel frame attracts/stores CW.
(water in the air, generates this CW).
the copper core attracts/stores CCW.
(normally the sand in the ground, generates CCW. but in this case, the CCW seems to be generated from the steel, and from the oxygen/potassium/calcium, in the gypsum side boards).
one metal to attract CW,
the other metal to attract CCW.
trawoger had copper and graphite touching the saltwater, BECAUSE NEITHER OF THOSE RUST IN SALTWATER.
otherwise, it would have been copper and steel in the saltwater.
Drannom
Quote from: TinselKoala on September 11, 2008, 01:22:37 PM
Yes, It's understandable.
See my machine, in this video.
http://www.mediafire.com/?gtj4zmemkl3
One disk spins clockwise, the other spins counterclockwise. The electric fluid flows both ways at once. The steel and copper spheres attract and absorb the corresponding fluids.
The brown capacitrols accumulate the fluids prior to discharge.
If the center electron-pipe is deflanged, the fluids no longer flow and accumulate.
I need to build a pyramid.
Hello TinselKoala
i look forward to see your video, the problem is that the format is in AVI, it makes your video much bigger 39 meg, if you convert it to mpeg format then it will be like 4 meg
i have a slow internet connection, and i am very interesting to donwload your video one night when my internet is free all the night, it will take more than 3 hours to get it
what your are saying is interesting as well for the Nitinnun theory
it was not me talking about coil and diode, all i still repeating is that is must be a resonating pyramid, and coil are a sigh that something is resonate in your pyramid theory, your CW and CCW seems to me like vortexes with their own frequency, i am not sure at all ! hahahah
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
Sorry about the file size. These days we just take it for granted, that one will have a fast internet connection!
I hope that you are able to view it sometime. It's a short demo of a modified Bonetti machine that seems to incorporate some of nitinnun's concepts. I think the pyramid addition will increase the accumulation of the electric fluids, if the walls are made of the right materials. I think I can get it to resonate using only the self-inductance of the electron-pipes, without using coils.
I need to assemble a 300,000 volt diode stack out of some bell-diodes. I'm not sure the ones I've got can handle the current, though.
And I am sure that the salt water idea could be right. If I replace my capacitrols with salt water aliquots in dielectric cannisters, and scrape the zinc coating off the big copper sphere, the machine should draw even more energy from the space charge.
nitinnun
why is it,
that nobody entertains the idea,
that this pyramid is powered,
by the same source that generates lightning bolts?
i might as well label it "lightning catcher".
because that is what i think it is.
statistically,
a lightning bolt is stroking the earth somewhere,
once a minute.
each lightning bold,
has hundreds of thousands of volts in it.
the source of lightning bolts, is the biggest/easiest source of electricity, on the planet!
so why is nobody interested in taping into it???
why is everyone concerned with leaching off of space time instead?
or milking ionic reactions with hydrogen?
easiest is best.
and the pleiadians have said that the pyramid, is the easiest source of electicity.
