Dark matter...i think i know what it is...check it out
Started by christo4_99, October 01, 2008, 12:15:14 PM
Magnethos
Very good.... I like people like you, people that thinks and rethinks the theories.
Some days ago I thought a similar theory (not as well as you) but that is true... If the sound can't travel throught the vacuum is because there isn't a medium to travel throught. When the propagation medium (the air) is present, sound can travel. So.... Why the energy can travel throught the space? The answer is easy... BECAUSE THERE IS A PROPATION MEDIUM, so the vacuum is not a pure vacuum. I don't remember where I read the next:
The Definition of Vacuum
1. Extracting all gases..... Result: There was thermal radiation
2. Extracting gases and reducing temperature..... Result: There was energy
3. Extractin.... + energy...... Result: There was Random Energy Patterns
So... pure vacuum doesn't exist. The vacuum contains energy and other things. We can perceibe it, but it doesn't means that there is nothing, because there is energy in all the universe. But we can't see it.
christo4_99
Quote from: brian334 on October 01, 2008, 02:29:13 PM
A better explanation for the irregularities of the universe than Dark Matter is, maybe the gravitational force exerted by a mass is not constant.
please specify "irregularities"...that sounded intelligent however vague
brian334
christo4_99
Quote from: brian334 on October 01, 2008, 02:48:24 PM
2 plus 2 not adding up to 4 is a irregularity.
ok, well then to try and fuse what you seemed to say with what i said:the light(or energy) that is exiting a system(galaxy) is causing a proportionately negative effect at 90 degrees which holds the system(galaxy) together...
brian334
We observe our solar system and make rules that work good in our solar system. We than try to apply the same rules to the entire universe, when our rules donââ,¬â,,¢t work out there in the universe we make things up, like black holes and dark matter and dark energy.
Maybe the same amount of mass does not always have the same amount of gravitational force.
