Low Cost HHO Applications!!!
Started by rogueleadr, October 04, 2008, 11:18:19 AM
rogueleadr
Hey Everybody,
This Forum is full of very useful information, but anybody has to admit that there it is very unorganized. :D. Not to underestimate though, its still very useful.
Anyway, the main point i wanted to make with this topic is that we should provide simple, step by step plans for making a simple, low cost, low voltage HHO on demand generator for use in nearly any vehicle. One set of plans for fuel injected vehicles, one set for carbourated. So far, it appears to me the following parts are required for a fuel injected vehicle:
1: Electrolysizer with bubbler
2: Pulse Width Modulator (PWM)
3: EFIE Controller
4: Timing Modification
5: Ceramic Treating for engine parts
6: Stainless Steel Exaust System
If i have missed anything let me know please.
Okay, so to my knowledge, you can omit the Ceramic Treating for your engine parts if you run of 97% HHO and 3% Gasoline/petrol. You may think that running off gas still is a bad thing for the enviroment, but from my reading it made it sound like at least 90% of the gas is burnt if not more. Correct me if i'm wrong.
Please Respond back and lets fix this problem by making it easier to put HHO in your Cars!!!
HometownHMS
Hello Every one
Jack here
I have a question about carburetors
I have installed my hho generated fuel line to the inlet ion the back of my carb
where the pcv valve would generaly connect.
My motor still runs with the metering screws turned in all the way.
I have found a ton of info for installing an hho system to a fuel injected ingine
but very little for carbs.
so I guess my question is
Now what?
Thanks
Jack
Rocko
       Im not sure how you came up with that list but I think I can simplify it.
1: Electrolysizer with bubbler            (Yes & Yes)
2: Pulse Width Modulator (PWM)      ( I never had to use one)
3: EFIE Controller                            ( I never had to use one of these either)
4: Timing Modification                      ( ?? thats just crazy )
5: Ceramic Treating for engine parts  ( have no idea what the hell this is for but someone is pulling your leg)
6: Stainless Steel Exaust System    ( Ha Ha Ha .... why would you need SS ?)
Heres a list that works for me and I actually use HHO on my vehicle
1.  a good working cell design   (one that doesnt need alot of electrolite)
2.  a bubbler or flashback arestor  with check valve between it and the cell
3   a relay to run off the ignition
4   o2  sensor extender  (spark plug anti fouler sold at Auto stores)
With this simple system I increased my MPG, better acceleration, plus I have no doubt that the emmisions are cleaner, why else would I have to fool the o2 sensor? :)
No you cant run 100% HHO with these simple  systems but the technology is out there and it wont be long before its available to all of us.
I got all my info from the internet you just have to screen out the BS
Rocko
Hey Jack
    The PCV is very important, keep that connected to the carb and run your HHO supply tube to the air cleaner close to the carb but ( MAKE SURE YOU HAVE A FLASHBACK PROTECTOR) like a BUBBLER or other between the cell and the engine. You may have to change the timming a bit and adjust the idle depending on the hho production of your cell.
Hope that helps
rogueleadr
Hey Rocko
Quote5: Ceramic Treating for engine parts  ( have no idea what the hell this is for but someone is pulling your leg)
From my reading, ceramic treating is required if going 100% HHO because the carbon deposites are destoryed and the pistons start to rust out. the SS exaust is for the same reason. it rusts out if 100% hho.
Quote4: Timing Modification                      ( ?? thats just crazy )
From my reading again, some timeing modification may have to be done because hho burns 10,000 times faster than gas, just a suggestion.
Real quick, what type of setup do you prefer for your electrolisizer?
and what excactly is an 02 sensor extender?
Thanks,
~RogueLeadR
