Gravity Mill - any comments to this idea?
Started by ooandioo, November 03, 2005, 06:13:20 AM
pese
ooandioo
Anybody made some new calculationst? Will it be possible to compress the shuttle with the gained waterpower?
I think, this will be the sticking point. If we are not able to give enough power to the shuttle that it is able to reinflate in e.g. 10m depth, the whole overunity will be gone.
Has anybody an idea?
hartiberlin
Maybe we can adopt this cartesian diver to extract energy from
the diving and lifting of the swimmer body ?
You only need a short relay latch push to put a weight onto the bottle
and then remove it again to restart the cycle, but you can earn all
the boyuancy force x distance upwards and downwars as output energy,
if you couple the diver unit to some kind of energy output production unit,
for instance a magnet-coil generator it will slide through.
Also  if you make the bottle more deep, the more output you will get at the
same input.
If you mix that with the ELSA principle, you would only need
to compress the outside water surface, so the center tube, where all
the water is pushed up does not need to be modified.
Have a look at this cartesian diver video:
http://video.google.com/videoplay?docid=-3177135341125519060
hartiberlin
hartiberlin
Okay, mix this with the ELSA principle and
we will have a winner !
Look at the attached animation picture. ( you must be logged into the forum)
If you put the egg into a pipe and the pipe goes a bit over the watersurface,
this will be the ideal combination.
