RAVZZ circuit : parts list w/ values?
Started by frog, October 10, 2008, 03:56:03 PM
Spewing
Quote from: ashtweth_nihilisti on October 15, 2008, 12:57:53 AM
Frog, many have made the Signal generator from Dave and Ravzz, including my self,  the signal generator is not the problem, the problem is getting the patience to electro plate the cell and find the best VIC for it.
If you need a signal generator there are many who can sell you one, just follow the D14 document down to a T, we did and its working.
Ash
Ahh, The primary coil of a old auto ignition coil is the best choke for the job, its also around 1.2 to 1.5 ohms per choke, i recommend using 1 of those if not 2.
Br, Hydro
ashtweth_nihilisti
Hi Hydro , we are going to try the signal gen into the toroidal and then 9 inductors like the new Ravi doc shows, we will do a gas flow test with the signal gen with out the VIC and after to prove Meyers is not electrolysis and works.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
frog
WOW...finally something that really works at LOW current...thanks
"When you change the way you look
at things, the things you look at change."
ashtweth_nihilisti
Frog, you have to EXPERIMENT bro, and stick with it, they didn't kill Meyers for no reason ;)
jas_bir77
replicating Ravi's & Dave's work
i am trying to condition my rods,but if i apply the current it gives out a constant 1.46-1.50 amps to the rods even after changing the main frequency it remains the same.
if i remove the 820+220 resistance from negative side the amps goes up to 2.5 amps & stays constant.
kindly reply a.s.a.p.
