RAVZZ circuit : parts list w/ values?
Started by frog, October 10, 2008, 03:56:03 PM
ashtweth_nihilisti
Quote from: jas_bir77 on October 26, 2008, 02:20:24 PM
in Research Paper on Ravi’s Water Fuel cell Replication by Panacea-BOCAF On-Line University on page 38 their is a message posted which says Message: "I have duplicated Stan Meyer's work, and have taken it several steps forward. First, during assembly of the generator, I have found that you must tune the tubes to the same pitch. I do it with a simple guitar tuner. Just clip it to the tube and strike it with a small brass (to prevent polarization) hammer. The easiest............goes upto........I don't add the toroid until final assembly, and try to maintain a 1/8' gap from the top of the tubes to the toroid. I am currently running 70psi in the generator. -End".
can anyony anyone explain "and try to maintain a 1/8' gap from the top of the tubes to the toroid". ??? ??? ???
Jas, this is the research part of the document, perhaps he is talking about the Gap between the tubes. I never heard back from that guy too.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
Farlander
I will check on the schematic and update the site in the next couple days.  This is the drawing I'm currently going off of, can anyone verify its validity?
I'm going to eliminate the 100uf caps and 100ohm resistors, since my power supply is a  very clean 12V wall brick.  I'm also changing the 100ohm resistors which are in series with the pots to 47 ohm resistors, and each pot from 10k or 47k to 5M.  Hopefully I will be able to play with a new range of frequency and pulse width.
