RAVZZ circuit : parts list w/ values?
Started by frog, October 10, 2008, 03:56:03 PM
frog
THANKS to all...
Now I'm scrapin this and going back to page 17 of "High voltage HHO by IronHead" and starting from ground zero.
But, I could use some help with his thread; Apparently, I'm only on the back half of this stuff...I cannot find the thread
pages that are mentioned in the current thread... i.e they talk about going back to page 14 or page xx and I hadn't even gotten
up to those pages in this post and when I got there there were no references to the info being talked about back on the pages
I was at??? I'm confused with this thread... was it split into another thread are there additional threads I should read first? Or
a book i should buy from this guy... ugh my head hurts I've been reading his thread for 7 hours straight now...
Frog
still researching this HHO stuff..
"When you change the way you look
at things, the things you look at change."
frog
@ Farlander:
I was wondering why you had those there... thanks for clarifying that... I had gotten so damn pissed at all the
different schematics I have found for this circuit...
@ ashtweth_nihilisti:
Dude, you have gone above and beyond helping me, thank you...
jas_bir77
in Research Paper on Ravi’s Water Fuel cell Replication by Panacea-BOCAF On-Line University on page 38 their is a message posted which says Message: "I have duplicated Stan Meyer's work, and have taken it several steps forward. First, during assembly of the generator, I have found that you must tune the tubes to the same pitch. I do it with a simple guitar tuner. Just clip it to the tube and strike it with a small brass (to prevent polarization) hammer. The easiest............goes upto........I don't add the toroid until final assembly, and try to maintain a 1/8' gap from the top of the tubes to the toroid. I am currently running 70psi in the generator. -End".
can anyony anyone explain "and try to maintain a 1/8' gap from the top of the tubes to the toroid". ??? ??? ???
Farlander
Yes, putting the toroid coil (step up transformer) INTO the actual cell very close to the water supposedly enhances the reaction because of the flux field created by the magnet.  This was first brought to my attention by the HydroStar? document, it was a for sale instruction manual on water fuel for cars.
frog
@Farlander
Dude, DOUBLE CHECK YOUR SCHEMATIC, listed on your site, compare the 555 pinouts to what you have listed.
HUGE difference in the connections, bet your frying a lot of 555's...
