Canceling Lenz's Law - Methods
Started by supermuble, November 19, 2008, 03:48:27 PM
Zorro
Free Energy Generator- The real deal!
its really interesting... just began replicate it.
wojwrobel
hello
i have been thinknig why not to switch magnet pole when we about to leave the coil ?
will it cancell lenz force? i think it would and even push away from the coil right?
what you guy think?
cheers from poland
wojsciech
Bruce_TPU
Quote from: DreamThinkBuild on March 18, 2010, 10:55:17 AM
@Tyson,
Thanks for the link, haven't seen that one yet. The idea makes sense though. In a normal generator the coil and magnet are fixed. As they get near since neither one of them want to budge the EMF/Lenz sets up a resistance which induces drag. Now if the magnet is just able to be spun/rolled (wrong term, more like pulled by Lenz pushed by EMF) away it will greatly reduce the drag.
It looks like from the video that the more load it speeds up, could be that the magnet is forced/rolled away at a greater velocity. Would have to build to see real measurements of what is going on.
http://www.youtube.com/user/Th3Generat0r#p/u/2/_9ktD7kAI7Y
That video and the other two...absolutely BRILLIANT thinking!  That is what I have been talking about...  Figuring out ways to USE Lenz to our advantage, and this fellow may have figured out a way...
This may indeed be the long sought after solution... elegant in it's simplicity!
http://www.youtube.com/watch?v=etFCzIe-D2Y
Cheers,
Bruce
BEP
When you short the output leads of any generator the first thing that happens is the stator field starts to collapse.
When that field collapses the voltage falls almost completely to zero. How many Watts are you putting out if the volts are zero and the amps are [anything you want]?
Of course the rotor increases in speed. This is because the generator is shorted and is no longer a generator. It is a flywheel.
This is a very common mistake made by folks of every technical level.
A short circuit is not a load when the generator is so weak the voltage collapses to zero. If they wish to load it they should load it with a light or resistor. Then it will slow down, if the field isn't caused to collapse completely.
I've performed short circuit tests on 2 megawatt diesel driven alternators and generators. It is a rather strange thing to see the engine speed surge near a dangerous sounding level when you close that 6000 amp 3 pole switch, shorting the generator.
I do love the man's style and getting the kids involved in such fun.
sparks
    I have no idea if this is doable but if the current in your output coil is delayed then the magnetic field it produces still follows lenz law it is just ill timed.  I know in an electric motor that insertion of a capacitor in series with a winding causes the magnetic field of that winding to manifest sooner than the magnetic field produced by what is called the main winding.  This causes a split phase motor to operate.  The magnetic field then shifts from auxillary winding to main winding.  The main winding consists of usually twice as many turns of larger diameter wire than the auxillary winding.  I have seen cases where it takes as much as a second for current to flow in a coil after being fed voltage and continue to flow after being disconnected from the line.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
