TALE OF THE IMPLODING TV
Started by HEYDUDE, November 19, 2008, 09:18:04 PM
otto
Hello all,
@Gobaga
so you tried it??
Otto
PS: is it impossible that when the TV imploded there was a mix of the 15..kHz and the 60Hz from the heating of the tubes???
Didnt SM mentioned this 12,6V?? AC!!
angryScientist
I see that the orientation of the flyback transformer is in different than all the modern CTR devices (televisions, computer monitors) that I have seen.
I think the same orientation  may be found in the Hutchison phenomenon, or at very least the Herzian waves (ie. electromagnetic waves [ie. electric and magnetic fields at right angles]) inter react with each other at the proper phase to "co-"manipulate the matter they interact with to produce the movement of matter (both electron and proton) in a similar sense or direction.
I think that the magnetic field, when it is rotating, does have a time lag depending on the direction of rotation. Left handedness over right handedness. (And I still can not absolutely verify this. Just something I have experienced, whether it be a falsehood or not, I do not know.)
I also think that the time lag determines whether a right handed or a left handed rotation will be stable or not.
I read in the Scientific American magazine a couple of years ago that the perturbations in the orbits of the planets could be explained by introducing a vector or outside force (direction of travel perhaps ) to the equation. This could be a prevailing force in what Tesla would call the aether, or I would call a character of the prevailing magnetic flux from our immediately larger system, the Milky Way galaxy. Anyway you call it, it is a force that prefers one direction of rotation to another. Same thing  exists in oriental philosophy and native American philosophy.
I don't know for sure.
Esa Maunu
To build up an artificial gravityfield, there must be a guide like nested, cylindrical EM field present, to collect and compress the ZPE field locally.
To build up such a field,  HV chargepoints must be accelerated, to create an EM field structure.
With a TV , it can be possible, both by a internal resonance effects, or with the external influence of the rotating magnetic fields, that is rotating in a radial E-field near the screen.
Esa
professor
Well unexplained things happen and will continue to happen
Matter meets antimatter?  Just as strange as instantaneous combustion it exists but what is its Cause?
I once worked for Canadian Gen Electric in those Years never had or heard of an incident like this here in
Canada. X Rays nah..... There are many more devices that produce higher amounts of X Rays than a shielded TV.
professor
Gobaga
Quote from: Esa Maunu on November 21, 2008, 12:59:24 PM
Esa
Great post Esa.
I think the shape of the induced effec had a great deal to do with the results.  like I said, there is a rotating field, and then there is a true vortex, and I think the xploding TV had the vortex, an aether vortex patterned into and odd combination of electric and magnetic properties, that resulted in this mishap.
