TALE OF THE IMPLODING TV
Started by HEYDUDE, November 19, 2008, 09:18:04 PM
BEP
Superposition of waves is not difficult. See attached pic.
What I wonder is what happens if the heater secondary is not quite in sync with the plate secondary AND superposition happens?
My other question remains: Why would someone so familiar with these circuits mention feeding a rectifier with a rectifier?
Bruce_TPU
Quote from: otto on March 09, 2009, 02:20:01 AM
Hello all,
thanks Bruce for the schematic. This schematic is very important!!!
I used a EZ 81 rectifier tube but its a wrong tube!! Im waiting for my 5U4 tube that I have ordered.
Now, electronics experts, show me what is sooooo special with the 5U4 tube. Im not so clever.
Otto
Hi Otto,
BEP is correct, about using the 5U4 GB and I would suggest the GE brand.  There is nothing special about the HV supply but rather, the "interactions" of different currents SM saw at the transformer.
I believe the part of the Schematic that deals with placing the different colors on the screen, (the part of the WHOLE schematic labeled "killer"), hit for a moment the "special" frequencies and this interacted with the HV power supply (the part of the schematic I clipped into the .pdf).  So, SM talks about how he began to study the interaction of DIFFERENT frequencies AND AC an DC current in the same wire, studying their reaction in the transformers.
Again, just a tube HV power supply, but the interactions of different frequencies at the transformer is what should be looked for, IMHO.
Cheers,
Bruce
slapper
Thank you Bruce_TPU and thanks -marco-
I can't avoid seeing the a common theme. High voltage coils mixed with high current coils wound on a common core.
Not sure how one would go about to combine the 2 on a single conductor though.
The following image may appear to some as plagiarizing (they'd be right) but here it goes.
Thanks again guys.
Take care.
nap
we are not alone :)
otto
Hello all,
you really think its only a oridinary power supply.
Its OK but then you can answer me my question:
Why is my my output electrolytic capacitor slowly charging?? The voltage rises from 0V to 4V.
The power supply is disconnected from the wall, the oscillators are disconnected from the wall.
Is it the tube or my copper core??
Otto
PS: yes, this is normal.
wings
Quote from: otto on March 10, 2009, 06:05:48 AM
Hello all,
Otto
@ Otto
Please can show us your current circuit ..... and some test setup picture
