Joule Thief
xee2
@ gadgetmall
Quote from: gadgetmall on January 31, 2009, 01:44:36 PM
  However i tested the input on a Fugi and its over 2000 ma
???   I have tested several Fuji boards and they were all using only about 360 ma with the large cap removed. I did not test with the large cap still on the board, but all of our tests have been with the cap removed.
gadgetmall
Quote from: Pirate88179 on January 31, 2009, 01:48:44 PM
Sorry for the delay in response.  I always thought so too as they both seem to act the same.  I was just repeating what I had just read in one of my electronic books.  On the chapter on vr's, it showed a photo of with just 2 tabs.  Then, under that was a photo of a pot and it has 3 tabs.  The only difference I can see is that with the pot, depending on which 2 of the 3 tabs you use, you can make the resistance go up or down on the same directional turning of the knob. (hard to put into words correctly)  In other words, if I want more resistance by turning the knob clockwise, I can get that.  If I want less resistance by turning the knob clockwise, I can get that by using the wiper and the other tab instead.  Does this make sense?  That is what I am using as Radio Shack did not have any 2 tabs versions.  (Maybe they don't make them anymore?  This book was about 20 years old or so.)
Man, with your years in tv/radio business and ham hobby, I'll bet you have all kinds of great stuff lying around.  That is great.  Several folks on youtube have suggested we try running the JT circuit from just an antenna, do you think this is even possible?  Art Bell, late night talk radio host (coast to coast show) said once that he put in an antenna array at his home in Nevada and it was the largest of it's kind ever built.  He said he had to have an electrician put special devices because he was getting over 200 volts from the air somewhere and it was blowing his stuff.  Ever heard of this?
Hi as a matter of fact i have heard of antennas pulling energy out of the vacuum  of space ! Thats Exactly how to make what they call and earth/air High Voltage Battery . You ground a copper rod in the earth and attach the wire to one end of a Hv cap then run another wire 200 feet up . and attach the other end of the HV cap . You will have a limitless  supply of high voltage only limited by you cap Voltage . It will light neons and probably CFs and florescent tubes .  i got two of everything from High powered burning lasers to tesla Flyback . down to metal that catches on fire when it gets wet and metal that is solid at room temperature and turns liquid at 108 degrees.Radioactive rocks and yea tons of ham radios  and junk i have collected from the past ..Im a Pack Rat . Here is one of my latest Toys . i need a tube for it . one was broke . 6CW5  This baby put out pulses from .01 kc to over 2.5 mc at voltages at adj. voltages up to 40 Volts . Now i wonder what a TPU or a Toroid / Coil will do with that !!  :o I'm gonna find out !
gadgetmall
Quote from: xee2 on January 31, 2009, 02:13:31 PM
@ gadgetmall
Interesting . i have three more i will check them for current draw when i rip em apart . Mine draws a lot but then it will light up a large CFL with no problem either . It light a 15 watt Blindingly bright ..
innovation_station
gadget     YOU GOT   2 of everyone knowen to man lol
well  im takeing apart my door bells ...   i want the coils ...  ;D
i just happin to have some pipe strap laying around ...    might even have 9 coils...  ;D
;D and still 1   BUZZER  ;)
ROTOATION FROM A PULSE ...   8)
AND GENERATED ELECTRICTY...     WILL IT WORK ?!?!?!?!?!
;D
IST!
MrMag
Pirate,
All pots have 3 leads on them. the 2 outside leads are the ends of the resistor and the center lead is the wiper. There were different configurations that were used in older style radios and schematics and I guess still today. If you only used one side of the pot and the wiper the drawing would usually only show these two connections. Also, in some schematics the wiper would be connected to one side of the resistor.
I remember having a long wire antenna probably each side was 60' long. We had it strung out in the yard with the center only about 4' off of the ground. It was a windy day an I think there were storms in the area. We measured close to 1000 volts on the antenna leads. We were not sucking in the ether, it is only a static charge caused by the wind with the possible help of the thunderstorms in the vicinity.
