Joule Thief
0 Members and 103 Guests are viewing this topic.
sparks
To charge that cap of 10uf or fill her up you will have stored in the cap say 200volts and .000010amps which is an input of volt amps of .002va.  not much wattage invested there.  Now dead short it into say .1ohm resistor.  Amperage equals voltage divided by resitance.  Your amperage will now be 200volts divided by .1 ohms.  Or 2000amps.  The wattage distributed or dropped will be amperage squared times the resistance,  4 times 10to the 7thwatts.  In that nanosecond of discharge you put out the same wattage as a 40megawatt powerplant.  The problem in this sceanario is the resistance of the circuit and the impedance of the circuit.  Mother nature does not like 40megawatts moving around in a confined field.  Your shorting device is going to be one of the problems.  Say it is a screwdriver.  As your contact approaches the capacitor terminal the insulating properties of air are going to be overcome and the voltage will start to discharge through the air.Now the cap will discharge at a rate where the resistance is in the thousands of ohms.  So now your I=ER is down to 200volts divided by 10,000 ohms which is .002amps.  The wattage disappated is now down to 20milliwatts.  Huge difference.  Still a gain but significantly less.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
nievesoliveras
Quote from: innovation_station
jesus ....   your a good guy!!
i just know  ;)
ist!
btw im not selling anything .....   it must be safe 100 percent     i think the jt is ok and the cam units as they are already in use main stream ...
Thank you @innovation. I wish you good luck on selling your inventions. You also are a good guy!!
Quote from: jeanna
@jesus. I understand. I know how to use photoshop, so for me it is quicker than learning a new program. I just need to install it, which is easy enough. I think today will be a good day for that.
(I have a macintosh and mac and windows are antagonistic operating systems, so I cannot just get the program you suggest. Thank you. I am switching everything even the mac to linux which is free and supported worldwide by open source folks who help each other like here. I am doing that a little at a time, though.)
Lady jeanna we all love you here. You are the only woman I know that do what you do. Keep being as you are.
Quote from: Pirate88179
@ All:
Have a look at this: http://www.metacafe.com/watch/2391318/nextreme_candle_power_demo/
I think this is very closely related to the Peltier Junction or a thermal couple of some kind. Not really related to what we are doing, but it could be with the addition of a jt circuit to use that same generated energy to light a bunch of leds.  The folks making this probably don't even know about the jt circuit.
Great! Isaw the video and what it states is correct. The heat wasted can be reused.
Quote from: jeanna
OK here it is... I hope  ;)
EDIT ADD: One at a time they draw 135mA total but when added together like this they draw only 45mA.
I want to perfect this a bit to find resonance, maybe...
jeanna
Thank you @jeanna. It is true that you know how to use photoshop!
i have about 300 of those diodes just the single wire one ...
i made you guys a video of my un modded cfl being powered by a cam unit and a 275vac cap
NOTE**    this is polarity sencitive ...if it dont work 1 way flip the wires  ;)
ist!!
http://www.youtube.com/watch?v=bkjN0GTlCRY
Great! If the light turns on without modification that is great!
@all
About the energy from thin air. I did the congiguration last year. The germanium diodes that the stores sell are not 1n34 germanium diodes. What they will send you is 1n60 and charge for the germanium diode.
The last voltage the device captured was 90 volts on the 100 volts caps. But if i wanted to use it anyway it only did a big spark and that was it. I did not know how to use the output.
I posted my work on the electrinium thread If I find the link I will post it as an edit to this post.
Jesus
Edit:
At this time my configuration to get energy from the air had an output of 59volts. But the last output I got from it were 90 volts.
I did not know how to use the spark produced from it and I disassembled it and used the parts for other projects.
This is the link for the photo of my energy from the air configuration. I posted it on the wrong place as a newbie.
http://www.overunity.com/index.php?topic=5479.msg131632#msg131632
Jesus
gadgetmall
Quote from: Mk1 on February 08, 2009, 02:59:36 PM
@all
Try it but honestly , that shit don't work , i made 4 of those but fell free to try.
Remember i told you i got a load of germanium diode sto extract electricity out of the air . well put 20 in series and parallel 20 more . It will extract electricity if it is very close to an rf source . Like My uhf or vhf walkie antenna , I think if you string up some wire 60 to 100 feet and make a yagi  it will pull some volts . I get 15 volts from getting them close to a transmitter . Also a cell phone .
gadgetmall
Quote from: Paul-R on February 08, 2009, 05:01:49 PM
Collect a couple of dumped TVs, monitors, microwave ovens.
With a soldering iron and a solder sucker, you would be
amazed how much useful stuff you can get (secondhand,
yes, but probably in good order) for nothing while you are
watching the telly in these long winter evenings.
Paul.
thats what i do !! recycle .. except for those special things..
innovation_station
well looks like future tests to be done ...
many things to do ...
if you watch my last vid ...   you will read the comments ....
for an improvment ...  ;) ;D
ist
thank you stephan  :)
@ sparks .....  come on bro ....    make the time ....    i want nothing from you ....  but i would like to talk to you
