Low Current HHO Production.
Started by Hydro-Cell, November 26, 2008, 11:40:39 AM
Hydro-Cell
i am currently working on a design for a HHO generator to be used for the production of electricity. either by way of fuel cell or ICE.
i will explain what it is that i have done.
the core of the cell is a 1 metre long 40cm diameter fibreglass tube, this tube has a 4km long coil wound around it in the form of a dipole.
the dipole is tuned to a frequency of exactly 42.854khz
when power is put into a dipole and pulsed at its tuned frequency resonance is acchieved. when this happens MAXIMUM energy transfer occours.
i have 1000watts of power going into this dipole. this consumes only 4.4 amps of power.
at this frequency and power the signal is capable of travelling round the world multiple times, it would be possible to send this frequency to australia on only 10 watts
so 1000watts in close proximity of water vibrating at 42.854khz(ultrasonic jewellery cleaners run at 42khz @ 60watts) will make anything the wave passes through vibrate at this frequency. in the case of water this can be a resonant frequency. depending on the type of water, contaminents and vessel the water is held in its resonant frequency is anywhere between 30-50khz. generally though 42.8khz tends to be a good frequency to use.
now that we have the water resonating @ 42.8khz its time to make a bit of magic happen. by introducing stainless steel plates to the water there will be an increase of electromagnetic pulses in the water due to the agnetic properties of the iron in the steel. by putting in just 1/2 an amp i can put out 1 litre per minute. 20-30 amps puts out near enough 100lpm. this 30 amps is split between the dipole 4.4 amps and 3 pumps which use 1.8amps each.
so thats 9.8 amps not going directly into the water. 20 amps in the water produces 100lpm (30amps total)
as the gas is being produced in monotomic form there is no implosive properties only explosions. i would like to split these gasses up and pump them into a fuel cell or use them in an ICE
any questions please ask
the dipole formers are available for sale for those who want to duplicate this experiment. you will have to wind your own coil, full instructions and wire supplier will be provided
starcruiser
So is this something you have tested and it produces from 1 lpm to 100 lpm?
Have you tried using this directly on a ICE powered generator?
Regards,
Carl
Hydro-Cell
hiya
yes this setup can be controlled by the amp input to produce as little as 1lpm upto 100lpm at the moment
i have this running on a 400cc honda engine and it consumes 14lpm at 3000rpm which drives a 120amp alternator to power the cell. the alternator load is 16 amps
the cell however is not small. its total size is 70cm diameter and is 1metre long with all its electronics bolted to the outer cover.
this cell is designed for land based pwer production not for use in vehicles unfortunatly
pese
Quote from: Hydro-Cell on November 26, 2008, 12:20:57 PMi have this running on a 400cc honda engine and it consumes 14lpm at 3000rpm which drives a 120amp alternator to power the cell. the alternator load is 16 amps
y
120 amp at 120V  at 12 Volts. ???
Ist mutch differences in Watts !  Must know , to follow yiu
60Amperes,
will ask the same information.
Pese.
Hydro-Cell
