Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
Grumpy
Quote from: TheBuzz on December 20, 2008, 10:40:08 AM
Interesting stuff. I made a note of Quick and Hull and I'll have to look more closely at that in time. As for the coil not being consumed, probably true but something is. Since there is so much atomic energy in mass you could never measure the loss, hence the Einstein quote in my tag line.
Nothing is consumed, only converted.   It just appears to run with gain because we do not see the entire picture.  The universe works on these principles.  I guess they may be called "creative forces".
        -Frank Edwards
ramset
Ouch!!
Sorry about the delay
600 ft driveway and the #&%@@# payloader won't start!!
Another foot of snow coming tonight
Chet
Thanks Grandma
CrazyFox
@TheBuzz
Cavitation occurs in the helical channels toward the center of the Von Karmen Vortex formed at the case and channel boundary. Vapor phase transition to cavitation ideally should occur at midpoint in the helical channels. A constant blue glow comes from that area along with considerable heat that is dissipated in the oil downstream to the nozzles. To much salt water and it won't work but just a small water to oil ratio in the emulsion works well. The working fluid (emulsion) will become caustic and Sol Gel ceramic coating over nickel plating on base metal of aluminum/nickel/bronze is advised. Sodium Hydroxide (Hydroxyl) is formed over time from dissolved Tritium. This aids in further fusion reactions in the mass part of the equation.
The Houston Chronicle on line may have more on cavitation from the science editors desk archived?
CrazyFox
@Sparks
Cern eddy currents are on the fringe of this cavitation topic. Cern may well become toast if they can not control external of the ring plasmas. Super conductors can handle a huge surge but they would be well advised to install magnetic shielding to prevent the reconnect with the fields mentioned. CME are not all alike either and that discussion goes of topic.
Cap-Z-ro
I read most of the threads posted here...as I'm sure many othere do.
I cannot help notice your incessant reference to the 'trolls'...who I assume are the same members who 'you' began insulting upon your entrance on this forum.
The same members who you repeatedly try to blacken with your muck, by aspersion, with cryptic references to the 'trolls that hound you so'.
Give it up...share your info...and stop whining like a petulant adolescent...and most of all --- move-on-with-your-life.
You are smart enough to follow all that right ?
Regards...
