Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
ramset
From user Maddan in the Witt's thread
    OK now this thing operates on "sonofusion" or "bubblefusion" (also cavitation, microcavitation, ...call it whatever you want) principle. Here are some links you do better see before posting:
http://www.youtube.com/watch?v=TMEpCpzahFY&feature=PlayList&p=A426FDF5BA3CD7FD&index=0
http://en.wikipedia.org/wiki/Bubble_fusion
http://peswiki.com/index.php/Directory:Sonofusion
http://sonofusionjets.com/
...and here is the proof that this is real - it does heat water (but in this video no OU is present, 'cause of the way it is done, but you can see what is hapening - Tesla did this with electricity):
http://www.youtube.com/watch?v=0oNZcLyCR_Q&feature=PlayList&p=C9FA62002A6557CA&index=100
...now here is the proof that also the OU can be obtained:
http://www.youtube.com/watch?v=yh_-DUKQ4Uw&feature=related
...but what is the difference between the last one and the "resonant sphere" approach? It is the far greater power input versus power output ratio and this happens 'cause the microcavitations caused by the resonance are more coherent (equally dispersed) in water.
So this is it, we just have to put it together the right way!
Let me say that most of the OU systems do operate on the same principle - 'causing an explosion causes an implosion which is of much greater power - and If we can catch the implosion power, then we get OU. On this operates the cold fusion (water fusion), hydrogen fusion (the MAHG by jlnlabs), Bedini motor, Newman motor, explosion implosion wing, ... the difference is just the cavitation in different materials.
Here are some other related videos:
http://www.youtube.com/watch?v=gR0YBAhY2PQ
http://www.youtube.com/watch?v=ONQlTMUYCW4&feature=PlayList&p=A426FDF5BA3CD7FD&index=30
Your comments are wellcome!
Dann
Thanks Grandma
madddann
1. Yes the cavitation is the key
2. Yes the cavitation is what makes the "fuel less heater" work - it was done already - i saw some of them on youtube and if you would like to see the one that is even more efficient of the "drilled holes" approach please see here (i also added some useful links there):
http://www.overunity.com/index.php?topic=6208.0
3. Some people (most of them) will just not believe this thing no matter what - probably 'cause one selfish idiot some time ago made the world go in the way he wanted to, and today we still believe this thing and serve the group of people that followed him...
4. Why complicate things when there is no need for?
5. Who am i to say all this? - it doesen't matter... i could be a piece of shit, i could be god... what matters is the truth!
...cavitation is present in our everyday life, we just don't see it (don't pay attention) ... so how do some of you open a jar? - (the hit and pop effect)
Dann
madddann
Oh well ... just saw the post above mine ;D
sparks
   Particle accelerator scientists trying to achieve hot fusion with more out than in found a very interesting anomaly about a self confining plasma.  This was that this type of plasma has a negative specific heat.  This to me means that as the plasma gets heated it appears to the field as dropping in temperature.  What is happening is that heat contained within the plasma is showing itself as being cold to the rest of the field.  Combine this with the electrostatic field flux densisty at the ion core things aren't normal around this type of matter.  I've got a feeling that Tesla discovered this negative specific heat a long time ago as he created a plazma in his spark gaps.  I also believe that he placed his plasma fields so that the ion field protonic charges which would radiate beyond the accelerated electrons circulating about the plasma  were utilized to capture radiant energy or what I consider space pressure.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
madddann
Exactly! If you saw how John Bedini uses his motor to capture the "radiant energy" you would see the similarity - just using electromagnetism... and he does it preety sucessfully.
Two months ago I came across theese videos: http://www.abovetopsecret.com/forum/thread400583/pg1
... I did watch them, but now the videos seems to be removed... i wonder why... anyway that was 4 hours of very good video about "Energy from the vacuum" from Tom Bearden and John Bedini... and there was another one that i found somewhere else about John Bedini - a guy filmed the complete operation of his motor and charging batteries with "radiant energy" ... here are some trailers of it:
http://www.youtube.com/watch?v=0PBHePZ_6U8
http://www.youtube.com/watch?v=X6EnDBjCjBw
I think all this videos are still out there, just search them in the right place  ;)
Dann
