Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
gadgetmall
@hartiberlin
Hi . This was My 9th Bedinipowersupply .I gave them Away for Christmas ! you are talking about the first one . The one with the 48 volt fan is running off a 12volt battery and Just Built last night .  . .
yes . i will get a number for you but this is Jesus's thread and i just posted My latest Video for encouragement for Him and His Project. We can Discuss It on My Thread Started By Goat` : Fusionchip's Bedini Feedback to Source!!! There is a picture of My fan Back there !
@Pirate . I will Try that . So many Things I was Asked to do with it .  Thank you Guys and Thank you Jesus for the Space here .
Mk1
@jesus
Your alternator project , if you recoil it with soft iron coil , you will reduce the magnetic pull and reduce friction , This is a old story that most won't even try.
nievesoliveras
Quote from: gadgetmall on January 22, 2009, 03:05:12 PM
@All
Here is My New Video of a Powersupply bedini FEEDING BACK TO SOURCE .. Any Comments ??
http://www.youtube.com/watch?v=BbSV-BqGnYw
Congratulations @gadgetmall!!!
I have not had good luck lately.
Quote from: gyulasun on January 22, 2009, 06:29:18 PM
Hi Jesus,
Very sorry that my suggestion did not work as expected,  I based it on your measured circuit you included in your Reply #143 a bit earlier.
I think the basic problem is the diode bridge connection directly to the Bedini output, a kind of isolation would be needed,  probably a third coil wound directly onto the pulse motor's presently 2 coils could directly drive the diode bridge, giving an ground-independent output  (i.e. the bridge cannot "see" any other voltage or current galvanically from the rest of all the circuits).
rgds, Gyula
Dont worry, I am just learning here. If it can be done I will do it.
Quote from: Mk1 on January 22, 2009, 08:01:50 PM
@jesus
I am trying to obtain a circuit that converts the alternator on a motor, but I forgot where I saw that information.
Jesus
nievesoliveras
@mvmcman
Thank you!
You should make your posts on the thread not on my email.
I received @gadgetmall feedback to the source circuit. I made some small editing and post it here as an example of a working circuit and as reference.
@gadgetmall
You are always welcome on this thread.
Jesus
nievesoliveras
@all
I tried this version of @gadgetmall circuit and the results were not different than the results from the circuit with the rectifier.
I used a flash circuit cap 300v 80uf and I configured the circuit as the graphic.
When I try to run the motor with all connected, it does not run.
If I disconnect the wire coming from the output coil to the 300v cap, the motor runs.
This is a crazy situation I have here.
Jesus
