Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
Cap-Z-ro
Hey jesus,
Got to admire your unwavering determination..
A thought occurred to me...maybe its been tried - maybe its just a wacky idea, I don't know for sure...so I thought I should toss it out there anyway...just in case it really is a good idea.
What I wondered was...is it possible to charge the battery using a pick up coil...and maybe even do work with the motor at the same time ?
I wasn't knowledgeable about pick up coils and such back I worked on the concept...so who knows...to me it seems half way logical though.
Regards...
nievesoliveras
Quote from: gadgetmall on January 23, 2009, 04:49:27 PM
looks like it is . test
I will test as soon as I get a well deserved rest and clear my burned out mind.
Quote from: Cap-Z-ro on January 23, 2009, 04:58:23 PM
Hey jesus,
Regards...
That is exactly what @gadgetmall claims he did with his first circuit posted on this thread. He made a video of his work: http://www.youtube.com/watch?v=LczzeeyfFoA
Jesus
Cap-Z-ro
Thanks jesus...I somehow missed that posting.
Didn't mean to steal any of your thunder gadgetmall :)...great set up and great potential.
Its encouraging to me that I was on the right track.
Regards...
gadgetmall
thanks guys . im proud of it and My second self runner charger .the first one Jesus is talking about is here for replication at a thread Goat started Fusionchip's Bedini Feedback to Source!!!  If you care to look . I want to Build a Newman motor Bad I just don't have anymore money to spend as i am unemployed and disabled  . In a Jam Right Now . The Newman Motor i will Build will run from Contacts only . I understand this type is very easy to get to feedback By adjusting the contacts and using bedini idea of capturing the back spike which is way higher that the run voltage .I think it Should work for Jesus on his electronic circuit if the transistor he uses switches fast enuff to generate good back spikes but i know contacts will . I got to go to sleep . Im dead tired too . Gnite .
Al
nievesoliveras
@all
I assembled the pots as the circuit depicts. The motor did not run. Playing with the pots I could not set the second pot, the output voltage had no change at all. Discharging.
I eliminated the second pot and the second neon bulb. The motor run when the pot was not biasing. Discharging.
I changed the pot for a 1k pot. By the way I was using 2 of 50k that I had available. the motor run very well but I could not find the sweet spot. Discharging.
There is just one spot with either the 50k or 1k pot that the motor does not discharge anymore, but it comes slowly to a stop.
The only difference I found is that the neon bulb stays on even though the motor is off. This is at that spot where it does not discharge anymore. But it does not recharge either.
I need better parts. Exactly the 10k pots needed with wire extensions soldered so it can be set on the breadboard without having tangled wire everywhere.
I will make some more tests and try another approach.
Jesus
