DEK motor with U-coreless coil or Lenz boxing against Lentz
Started by woopy, February 02, 2009, 03:31:57 PM
woopy
Hi Chris
houlala  i hope that there will be a good possibility but i wiil wait until better understandind and diagram for this technology.
at the present i am making measurement around  a pulsed UCC as per picture here under
what i have noticed so far is
there is a train of 9 magnet s beeing inflenced by the pulsed UCC  3 in the axis and 3+3 sideway along the axis
if the force of the pulsion on the center magnet is equal to( let's say ) 1  than the following magnet which are outside of the UCC get 0.5 force each  (one repelling and one attracting)     that is for the central magnets   1 +0.5 + 0.5 = 2
the sideway magnet get less force  and the one traveling in the middle of the UCC get  a force  of 1  and the following magnet  get a force of 0.25 each (attracting and repelling  )  so       that is for the outside magnets   0.5 + 0.25 + 0.25 =1 and as there is two side the force =1 + 1 = 2
so to resume  a UCC with one magnet  give a motive force of   1 and if you organise a "train of 9 magnets you get  a  motive force of 4  under the same pulse.
elle est pas belle la vie!! ;D
Laurent
Use 4 big cylindrical magnets and feed the coil with DC. If you want more info tell me.
Edit: Just realized that the suggestion wouldn't work.
gyulasun
Quote from: Kator01 on February 03, 2009, 07:18:22 PM
Sorry gyulasun,
too much traffic going on at the moment in my mind - got it all mixed up.
See attached pic with corrected diode-position.
Kator01
OK,  thanks!  Maybe a small update at Thane's thread is also in order where you uploaded the previous schematics.
rgds,  Gyula
woopy
ouups  :(
just a small correction  of course in the outside traveling magnet     the one in the center  get only 0.5 force  and not  1 as i mentionned   but the total result is  4 anyway
@all
to the interested people whou intend to help for the timing method  i  enclose a picture of the one i use     very simple  you get a CD box and normally  on the top  of it there is a blank CD transparent  for protection   and than you make your division as you think and let spin the transparent disk with the marking to practically see what happen   good luck
@BEP
just for fun i found a picture of the 8UCC  and the very tortured and bordelic 8XUCC ;D
good night
Laurent
BEP
Quote from: woopy on February 04, 2009, 04:44:54 PM
@BEP
good night
Laurent
The green one is very much like mine. I've been looking for the photos of mine - not found so far. The coil creates a well defined dipole field between the loops that is completely surrounded by a larger reverse field.
I used mine to rotate a large copper disc. It was interesting to have the two fields turn inside-out on reversal.
BEP
