DEK motor with U-coreless coil or Lenz boxing against Lentz
Started by woopy, February 02, 2009, 03:31:57 PM
nievesoliveras
Quote from: Kator01 on February 18, 2009, 12:37:08 PM
Hi Jesus,
which pirate you mean ; Pirate88179 ??
And which thread : Jule thieve ?
Kaotr01
That is correct.
Jesus
woopy
@all
I am testing all what is possible with  UCC (within my possibilities of course)
the test bench is very simple as usual        i simply let pendel  and swing different arrangement of magnets through different   UCC  and scope the results
at the first glance  Lenz is a very CORIACE  boxer and does not  intend to be beaten so easily   even against himself  :P
@ Yucca
i will probably need your soft to go forward so if your offer is always in value i am very interested
good luck at all
Laurent
Yucca
Hi Laurent,
Your oscilloscope looks very nice with maths functions, what make/model is it?
Yes, I have finished the software for now, so if you do order boards then I can PM you the software anytime you like. Then you just load the program and solder wires onto the controller.
The software now has these features:
User can specify even number of rotor magnets in one line of the code before programming.
adjustable delay period specified in tenths of degrees. (also displayed in microseconds).
adjustable pulse width specified in tenths of degrees. (also displayed in microseconds).
accurate RPM readout.
Strobe light LEDs.
Optional audio feedback click once per revolution.
I plan on adding one more delay and one more pulse output for further experiments.
My motor has been running for over 24hrs at 200RPM consuming about 40mW, when I throttle it up it throws magnets at 1500RPM because they are only stuck on with doublesided tape. I want to build a wheel that will go faster.
woopy
@yucca
here a picture with denomination of the scope
i have ordered today the 2 moduls for programing the timing
as soon as they arrive i will contact you for your soft
@all
completely out of topic !!  and just for fun   i used my UCC pendulum test  to try  to replicate the Veljko Milkovic small pendulum chariot    it took me half an hour to build this crappy replication  but it works fine and it is really fascinating to see the gravity walking horizontaly :o     perhaps it will be a new thread for this purpose
good night
Laurent
nievesoliveras
