Peter Lindemann, The Mechanical Engine: A Re-Evolution of Bessler's Wheel
Started by hartiberlin, February 03, 2009, 11:21:29 AM
BAHammer
Quote from: rlortie on February 03, 2009, 03:30:23 PM
Is this to imply that I can now talk freely of this device and receive recognition for my efforts for which I am not recognized for in this article?
Cc to Peter Lindemann via private mail
Ralph Lortie
The question might be something like ; How much downward force is generated by the pendulum while it is swinging ? I'd say very little. The force applied to it's point of rotation would be in the wrong dircection negating any hoped for gains.
wattsup
Actually, position #3 is not the only hold back. There will not be enough rotational momentum to get over that center incline that is supposed to unlatch the ball at position #3. Don't forget that if the wheel can unlatch, that is "work" being done above and beyond the turning aspect and that will be very difficult to achieve.
Also, like I said before, the balls have to be much bigger. The bigger the balls the greater will be the excess at #3. The most difficult part of this type of build will be one of wheel balance that has to be done with all balls held inward or outward at the same position and the incline removed. Only then can the balancing be done. 1 gram of unbalance could kill it right from the start.
I like these ideas because I find them a relaxing change to the regular stuff I do with coil and pulses, etc.
But what I am mostly puzzled about is why all this secrecy in not being able to disclose this or that. Do you really think this device deserves so much cloaking. Do you expect to make millions with such a wheel and why. I don't get it.
rlortie
Wattsup,
My name is Ralph Lortie,  I have  two shops attached to my house, one being for metal work and the other for woodworking.  I do research on physical build gravity wheels as a full time hobby and  second career. I work on a contingency basis, meaning I front all expenses. If a runner is developed I receive a share of the profits and recognition.
I am noted for building working models for those who do not have the skills or resources to build for them selves. Submittable designs are received in strict confidence.  I cannot discuss them until receiving authorization from the submitter.
The only cloaking here is; I could not talk freely until that authorization was received. It does not refer to anyone other than me.
Ralph
BAHammer
Quote from: wattsup on February 05, 2009, 04:43:53 PM
   wattsup,
These guys really should take the time to learn some engineering first.
When the fuckin weight swings out, it would pull the point it swings from in that direction.
Then, if it is caught and held, it would have noticeably changed it's center of gravity. None of these geniuses have figured that out.
Then after it rotates past bottom center, the weight would hang from it's pivot point. And when it rotates past top center, it can catch a latch to store kinetic potential energy until it could swing outward.
While it's being held in closer until it reaches the #2 position to swing, the weight at #3 and maybe #4 would need to be in an outward position to have an over all net positive effect.
Not sure how people keep missing obvious things like this. More money than brains ?
