ENERGY AMPLIFICATION
0 Members and 45 Guests are viewing this topic.
http://worldwide.espacenet.com/searchResults?compact=false&ST=advanced&locale=en_EP&DB=EPODOC&PA=siegfried+stargard
and from all his ,Siegfried Stargard,work disclosures about gravity,amplyfing et cet.
zvs-related:
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=28&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920507&CC=DE&NR=4035445A1&KC=A1
A source of questions and probably for some with answers
        CdL
weizisky
Quote from: gyulasun on October 15, 2013, 04:32:28 PM
Hi weizisky,
So the L1C1 tank is a low impedance while the L2C2 tank is a high impedance circuit. This means that the peak AC voltage across L1C1 is smaller than across L2C2, when you apply the same power to them (assuming the losses in the tanks are comparable) while the input current to L1C1 is higher than to L2C2. This means that coil L1 has a stronger magnetic B field than L2 while the E field is higher in C2 than in C1.
I assume you mean now that the speed of electrons is higher in C2 than in C1 and the possible ether particles also have a higher speed around L1 than around L2.
Now how to proceed?
Hi Gyulasun, everyone
Gyulasun you are absolutely ringt. Then we can know which tank is easier to transform and  stimulate energy to another tank in what kind of energy.
If you get that, you can understand ALL TESLA COIL working method. and will know which enventor's device does work., which one does not work, which one is better, which one is not. and Forest also can know why Tesla always use HV in depth.
so, you can make your free device now.
one more thing you have to think, where the free energy come from? It is not from eath, air, Zero pint, it also not from cap, coil !!!
if you get anwser, to make free energy is a piece of cake .
Hi weizisky,
Now how to proceed?
F=BLI
magnetic B-field + coil + field forces difference :
Mukherjee
http://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=2733719A1&KC=A1&FT=D&ND=3&date=19790215&DB=EPODOC&locale=en_EP
here the description with language translation possibility:
http://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=2733719A1&KC=A1&FT=D&ND=3&date=19790215&DB=EPODOC&locale=en_EP
forest
actually free energy comes from resonance and resonance must be in resonance with energy which is directly powering Earth, simply like Tariel said, nothing complicated.
I'm still not sure about the role of HV :-( except obvious thing like Tesla first attempt to pass current through upper stratosphere where air is rarefied. With today mosfets able to pass many amperes in low voltage there is a way to make it work in low voltage too...
My question: what is meant by using the expression "resonance",
where is "resonance" how defined  ?
here are probably an answer or better an explaination trial:
http://worldwide.espacenet.com/searchResults?compact=false&ST=advanced&IN=dinnan&locale=en_EP&DB=EPODOC&PA=Meta+c
from the first publication:
[0024] Resonance is widely misunderstood. There are several slightly differing views across all the different scientific disciplines as to what resonance represents and means to a circuit. In radio theory, resonance is accepted as special frequency and phase relationships which create a self reinforcing "boosting" effect on the signal which closes the gap of peak to RMS (Root Mean Square) power of the signal. In one aspect of audio theory, resonance is a special relationship between frequency and the characteristics of matter in an object which creates a "bootstrapping" amplification effect which causes a catastrophic destructive effect on the material. In energy theory, resonance is accepted as the alignment of the phases between the voltage and amperage of a circuit which creates an idealized energy state. This state is determined by the calculation of the power factor of the running circuit. [/font]
I am never wise enough to not to take help by people or dictionaries
        CdL
(Also by my gramatical and orthographical errors
cause errare humanum est)
