ENERGY AMPLIFICATION
0 Members and 130 Guests are viewing this topic.
Tenbatsu
Magluvin, any update on your experiments?
This thread is desperately lacking your input at the moment.
Magluvin
Im still around.   Had some issues with how things are working.  My whole weekend was shot.  Bang bang
I am picking up some parts I need tonight and back at it.
I know Teets says " dont you see the amplification in the igniter pat"    and im trying to.    I see the input being held back by the large inductor, as to where there seems to be a constant current flow from the input. But the short outputs have me thinking that over the period of time from pulse to pulse, It looks like the continuous input could add up to the total of the output as it is short. Maybe Im wrong, and being that the output pulses are so big and close, that the load sees it as a continuous flow, depending on the load.
Like if we have 10w continuous in and pulses of 1kw out, are we sure that the time span of output is larger than 100th of the input?   I got a cap on the primary which seems to help prolong the output, but it lowered my peak a lot.
I also took some time to read some of the thread Watts recommended above and it does go over a lot of what we are going for here.
Be back after work
Mags
Magluvin
Tito is right. We should stop what we are doing and just go with Stubblefield coils.  Its really cool.
Not
Not that the air battery isnt very cool. I like it a lot. But there must be some life expectancy from it.  Its not a 100 amper nimh D cell.
Maybe there is a connection to what we are trying to do here. Im stickin with what we came for.
I know Teets is  wanting us to stubble a bit, but I gotta keep on track. I dont always have a lot of time for what Im working on.
One Mocopozo vid uses the coils as flywheels.  1 being switched and the others on the loads are being kicked to drive the loads. I like Moco's stuff. Zeropoint321 turned me on to his vids a while back..
Still workin on it guys. Will post the second I have a vid goin.  ;]
Mags
Magluvin
Quote from: Tito L. Oracion on October 11, 2010, 05:43:21 AM
See SM made use of stubblefield tech in one of his tpu, cause a very small energy like a .5v is enough to amplify.
Well, if we had a small solar cell, we could charge a battery and use that as input also, and during the day have another tiny solar panel running the circuit.  Thats all fine and dandy. Stick a penny and a nickle in an Orange and we have something to work with.  Its the Amplifying that we are after.  If we can amplify, we dont need the source anymore, or at least we should be able to replenish the source from the amplified output.
I get the point that we can make a small voltage into a high voltage.      Could it be that the short stout primary is the key?  Could it be that if set up with a cap to oscillate, it is a hard field to be damped by a secondary because it has so much going for it, and so little resistance and few turns?
I have been looking at some variations of coils I have that are of very short turns and varying stoutness.
Ok the source never sees the load directly, only to use an inductor to induce a high voltage charge in a cap at a low current rate from the source.. Now probably any cap discharge into a low ohm will be disruptive of sorts. So 500v from a tiny cap will set off an lc resonant circuit, being of the primary and cap. Should the cap stay switched ON with the primary for a bit to continue oscillations? (this is what I am fighting with in my setup now)
Now that MIT vid with the dissectable jar cap was astonishing.   If we were to just use a wire from the inside to the outside of the glass, would there be electron flow in the wire when it discharges? Just a jiggle?  Is there electrons freed from the plates stuck to the glass?  Are there more electrons on one plate than the other when removed, yet no charge differential between them when dissected? Questions questions.  Caps   no electron exchange. Just the force Luke.  We are now in the 4th dimension.
Never Kill The Dipole      Does that mean never a discharge from the Dipole? Or only kills after a very long time?
Are we to just use the source as a spring (jiggle) and it is never depleted?
I understand that you are trying to show us what can be used as a source Teets, But if we never kill the Dipole, then what does it matter what source we use?   Amplify?  Dats da quekstion.
I wonder if the stubble works in a vacuum?   Stubble Hubble Bubble.
Mags
Magluvin
Hmm  Moco has something. I didnt see the cap on the load section.
I did a sim using 1 load light bulb. Looks good.  The inputs are a pulsed type that go along with the output. But the output is 5 times more.
Well  if this is it, then Teets has given it here.  =]
This will be a lil project I can whip together pretty quick.
I am going to take notes on what I have together now and disassemble and put this baby to work.
Here is the code
$ 1 5.0E-6 5.459815003314424 50 5.0 43
w 384 192 384 464 0
c 592 464 592 192 0 8.87E-9 -9.34392179615871
l 592 464 384 464 0 0.0020 -0.1979942080069645
v 752 464 752 192 0 0 40.0 20.0 0.0 0.0 0.5
w 752 464 592 464 0
l 752 192 704 192 0 0.0021000000000000003 0.1508358744494478
181 384 192 592 192 0 22216.037624033113 0.67 7.65 0.4 0.4
w 640 192 704 192 0
159 704 288 704 352 0 0.1 1.0E10
w 704 288 704 192 0
w 704 352 704 416 0
w 704 416 752 464 0
w 688 320 656 320 0
R 656 320 656 256 0 2 496.0 5.0 0.0 0.0 0.1
d 640 192 592 192 1 0.805904783
o 3 16 1 291 74.82888383134222 9.765625E-55 0 -1
o 6 16 1 291 299.3155353253689 9.765625E-55 1 -1
Mags
