ENERGY AMPLIFICATION
0 Members and 68 Guests are viewing this topic.
Jeg
Two caps charging in parallel, discharging in series with one switch. After a lot of drawings i think this is the most simple way to accomplish this. Any corrections would be appreciated.
Also, a zener which as you have told again, stops conducting under some specified voltage and current stops to flow through the gap even if the gap is fully ionized.
When the switch is in the lower position, caps charge in parallel. On the upper position caps are connecting in series, voltage is being double and discharge happen through a regulated spark gap.
Jeg
Quote from: gyulasun on June 09, 2014, 05:24:38 AM
Hi Jeg,
In the schematics from the video you uploaded above, the two diodes are labeled as КД203А  which 'translates' to  KD203A (and not KB203), ok?
And these diodes are not Zener diodes but 600V peak reverse voltage and 10 Amper rated 'normal' Si diodes.
http://www.ec-centre.com.ua/diodes/alldiodes.php   These types are approximately equivalent to the now obsolote
1N2258 diode type.
On ebay you can buy КД203А type:
http://www.ebay.com/itm/25-PCS-KD203A-203-SILICON-RECTIFIER-DIODE-600V-10A-/161074727062
One more thing: you mention that "The circuit that feeds this coil, also uses two zeners in a Tito like arrangement.."
I wonder how you know what Tito's arrangement looks like??   8)
Gyula
Hi Gyula
I show this zener symbol and I guessed that is a zener. On other places in the schematic, diodes have the usual diode symbol.
About Tito's arrangement sorry for called that this way, I should have call it Tito's possible arrangement.
Can u pls suggest a switch for the above last drawing?
Ps. In Daly's schematic is there any sense to have a diode on the secondary like this? But there is a sense of having a zener there isn't it?
Neo-X
Quote from: Tito L. Oracion on June 09, 2014, 04:13:51 AM
Di bale friend naman tayo e. ;)
Nasabi ko naba sayo na mabisa ang dahon ng guyabano na may dahon ng abokado sa diabetis at kung may balbas pusa ka isama mo rin. pakuluan mo ng 15 mins at uminum ng isang baso pag gabi.
kung gusto mo naman subukan yung kay reh herbal na nabibili sa robinson at sm "KINGS" ang pangalan.
at hwag ka masyado sa kanin o hwag ka masyado magkakain.
at lakipan mo ng ehersisyo.
otits  ;)
Palagay ko di uubra sakin ung dahon ng abocado kasi masydong mataas ung diabetis ko saka meron naman akong iniinom na gamot ang kaso nalilimutan ko minsan iminom kaya di bumaba-baba ang diabetis ko. Lagi tuloy ako nanlalambot.
Sana balang araw magkita tau para magtulungan tau sa paggawa ng ou device. Ang hirap pala gumawa ou device kung nag iisa ka lang at walang katulong. Marami akong gustong gawin na experiment kaso di ko magawa dahil di ako magaling sa electronics.  :(
Tito L. Oracion
Quote from: Neo-X on June 09, 2014, 06:59:28 AM
Di mo pa pala subok yung wonders of herbal medicine, alam mo bang merong kayang gawin ang herbal na di kayang gamotin ng botika.  :) :o 8)
well, nasa sayo yan, ako nasubuk kona.
actually di naman masyadong kaylangan ang maraming alam sa electronics para maka gawa ka ng ou pero malaking advantage yung maraming alam sa electronics syempre.
Tito L. Oracion
ok!
Lets say we have an inverter, to charge  the battery using stepdown X is not efficient, but if you will just use resistor to lowerdown the volts is much cheaper in usage from the source. 8)
