ENERGY AMPLIFICATION
penno64
Wonderful !
Now introduce an earth/ground connection
Penno
forest
Wow!
Great result Mags!
Yeah,it's time to connect it also to the bigger ground,bigger metal,something having a lot more free electrons.Maybe just grounding a case is enough ?
Magluvin
Ground
How can we avoid using ground and get the same effect.   I get the concept of using gnd. It is the same as using a suspended metallic object as a gnd for a crystal radio set. It works, but the earth is larger.
Like when I touch the casing of the spark coil, I simulate a stash of free electrons, in the form of a capacitive connection to the primary coil in the casing, thus giving our charge caps something on the other side to work with , giving the ability to charge quicker. When I touch that casing, charge flows in and out of me as fast as the polarity change from the neon transformer.
But,  in each case, whether it be earth gnd, human ground, or just rigging the neon transformer to directly charge the cap via bridge rect, we increase the current input. No free lunch yet. And of all, the direct method will give us a very very fast charge, at .6a 12v  7.2W    Just the av plug one ended to the neon transformer, max power is .75w tot
and we have to wait for full charge.
I am doing another vid in a bit.  Using 2 SIDACs in series, putting 2  275v caps in series(.33 and .22 = bout .13uf)
So now she is gapped at 500v.  I am also using more capacitive winding to the casing. Some of it will be bringing the input above 100ma. So about 50ma is being consumed after the neon circuit.   These sidacs are fun to mess with. I was afraid they would not handle much, but they are exceeding my expectations.  Ebay  Cheap  Obsolete parts.  So the trisil should blow me away.
I have tried to run the spark coil from the neon transformer directly and with spark gap alone, due to the neon is a couple kv, it produces a starting spark at about 1mm or so. But it cannot produce the spark from the coil alone.
Maybe the AV plug can be used to kick an lrc.
Mags
IWD
I forgot to mention That effeciency of av plug can be also raised by adding selfinductanc serialy connected with capacitor.
