Tesla Patent 382282, and all related to his transformers/converters
Started by clone477, February 07, 2009, 04:31:11 PM
Room3327
The converter pictured above has 1,800 turns of wire total in it.  As a transformer it has a 10 to 1 winding ratio, which at 9 volts input, will give less then 1 volt of AC output from transformer action.  The current available from transformer action, with the 10:1 ratio, if input is 500 ma. there should be 5 amps available at the output. The high speed of the rotating component I believe will produce a high voltage, low current at the output, on top of the small amount of transformer action.  If the rotation boosts the voltage to 100 volts and I have 5 amps available at the output that's 500 watts. With the field rotating in one direction only that high voltage boost will be seen as DC spikes (kicks) on top of the <1 volt of AC. So this would be an AC in and DC out device.  (With 2 things going on at once, and designed for both, this is a strange device.)
Each field winding has 400 turns of 29 ga. magnet wire and measure 4 ohms at 4 mh. Each output coil has 45 Turns of 12 ga. magnet wire. The circuit potential of this device is dependent on the output wire and the core material it is built on. This is built on a soft steel core so the input frequency will be limited to about 500 Hz which limits rotation to about 30,000 RPM (too low to harm this design). The 12 ga. wire is good to 20 amps @ 120 volts so 2.4 KW max output,  I think it will handle all I can give it.  If this same design was built on a ferrite core it could be taken to a lot higher RPM. Ferrite can go to about 50 KHz which is 3,000,000 RPM but even keeping it to audio frequency 20KHz is 1,200,000 RPM.
I put a lot of turns into the field windings to create as much magnetism with them as I could from a small input, and the steel core to boost the magnetic field from that little input.  As can be seen I used speaker wire to bring out the field windings, I thought it was only fitting.
SM said to think of speakers with this device and I did.
giantkiller
The only thing we move is the field by hitting it with another field.
We move the field by pushing on it.
--giantkiller.
pix
Hi,
I think that this Tesla patent is the key to succesful TPU replication.Weak magnetic field revolving very fast ALONG circular path made by magnetic material- let's say core made from insulated soft iron wire or ceramic ferromagnetic ( for higher Hz aplications).This kind of magnetic field action we don't have in normal transformers or even AC motors. In transformers magnetic field is changing direction only: forward-backwards like push-pull.In AC motors magnetic field vector is rotating 360 degree.So in both Lenz law is fully in work.
But...still I am wondering a quote about something like "squeezing electrons out of the wire like squeezing water out of the garden hose".
Question: do gaussian type magnetic pulse along conductor actually have kind of effect on the electrons?
Regards,
pix
Room3327
Pix,
   I don't know the answer to your question, but if this is the right direction to achieve the TPU it is perfect, because this has already been patented, the patent has already expired and it is already in the public domain!  No one but Tesla can take credit for it, not even Steven Marks and anyone can build, sell or do as they please with it, individuals, companies etc.. Trying to develope an idea like this would be the best way all of us here could go, no hurt ego's, no bad feelings, no one individual making all the money off it, no one who can claim it was their idea. A truely open source project for everyone on Earth to share as I believe we are trying to do here at this Forum. Tesla said he was not doing his work for the people of his time, but for the people of the future.  It has now been 120 years since Tesla patented this device, I believe the future is here now.  Tesla carefully hid in his patents the idea that this device could produce more energy then it consumed in order to get the patents in the first place. If you look carefully at this Tesla patent 390721, his last patent on this device, it is apparent that this was all about speeding up the rotation of the field and also being able to regulate it.  He only had at his disposal mechanical methods of doing this and consequently was still limited to the realitivly slow speed of 10-15 thousand RPM maximum. 120 years later we now have a lot more to work with.
pix
Hi,
Yes,this is a question I am still looking for answer: sharp magnetic pulse along conductor.The variation of this could be adding some weak but constant magnetic field bias  to this conductor and then pulsing it with short magnetic pulse.Maybe this would be the case for Tesla idea of magnetic field revolving along closed circular magnetic path.In his aplication he used soft steel wires as the core for toroid.
Do anybody wonder what is happening,not to the coils wound on this core,but to the steel wires core is maid of.
I need to find out if analogy for squeezing water out of the hose applies also to electrons in conductor when we apply gaussian magnetic pulse.
Anyway, if it is not the case, still Tesla's idea of high speed magnetic field revolving along circular path is very unique and worth to try what is effect both on the coils wound  on the toroid and on the core wires itself.
Regards,
pix
